What gloves work?
What gloves work?
I have been using a butcher block finish for my projects and the can says just wipe on. So I purchased some basic plastic gloves at home depot. Ok stop laughing, they only last a few minutes before falling apart. What should I be using and where can I purchase them?
- a1gutterman
- a1gutterman
I can not tell you if it would stick or not. You could try it on some scrap to see what happens. Shellac is used as a sealer, so it might work.cadman84 wrote:Thanks guys,
I just assumed I shouldn't get it on my hands.
OK new question.
on another thread the consensus was to use Shellac for a crib. Can I use shellac over the butcher block oil that I have already applied?
Tim
Butcher block oil is a non drying oil. Don't think you can successfully cover it with any finish.
P.S. This site and the video shold interest you. http://www.taunton.com/finewoodworking/ ... x?id=28481
I use food service gloves from Smart & Final. Really cheap, and a just keep changing them. But for Butcher block oil iI wouldn't bother. Also the gloves are not tight fitting, so I don't use them for small detail work, there I use surgical gloves. Costco and Walmart sell non-sterile latex gloves for about $12/100
Gary Kalyn
Kalynzoo Productions
Woodworking
Porter Ranch/Northridge
Los Angeles, CA
Woodworking
Los Angeles, CA
Gary Kalyn
Woodworking
Los Angeles, CA
Woodworking
Los Angeles, CA
james.miller
Another option is Nitrile gloves from Harbor Freight, $7.99/100 when they are on sale. They work well with most finishes but they doesn't work well with Ketones so you would need something else if you use them. I have bought heavy duty gloves from Rockler http://www.rockler.com/product.cfm?page ... ter=gloves
Jim in Tucson
osx-addict
another question should be asked here regarding the above question.. Is food going to be used on this same surface? If so, I would think that you need to make sure you use some sort of finish that won't become part of the food being prepared.. Of course, I could be wrong...cadman84 wrote:Can I use shellac over the butcher block oil that I have already applied?
