Do I belong to a Shopsmith?
Cavediver
Post by Cavediver »
Please help. I'm lost and don't know where I belong. My owner found me in a box with a bunch of 10E parts, but I don't know if they're my family or not. If you know where I belong, please tell me!
Thank you,
Rusty
dgale
Post by dgale »
Cavediver wrote:Please help. I'm lost and don't know where I belong. My owner found me in a box with a bunch of 10E parts, but I don't know if they're my family or not. If you know where I belong, please tell me!
Thank you,
Rusty
That is the original 10E table riser - this was available as an accessory and then they switched over to the more typical table riser that 10ERs have. I need one for one of my 10E if you are interested in selling it (or trading for other 10E/10ER parts) - send me a PM if so. I presume the newer version is the preferred design (since this is what they switched to and what everyone has) but I'm a stickler for restoring my 10E's with the original 10E stuff, however illogical that sometimes is.
Here's a couple photos of what it should look like cleaned up, as well as the original manual:
'82 Mark V 500 #96309
They also be somewhat rare.;)
Cavediver
Post by Cavediver »
Well I'll be darned. My initial guess was that it belonged to the table assembly, but I couldn't figure it out for the life of me. After looking around for it and only finding images of the later screw-type setup, I started figuring it belonged to another machine and got tossed in my box by mistake.
The funny part is that I was about a day away from ordering one of the later versions, figuring they're reasonably cheap and it wouldn't hurt to have it :D
dgale, I'm not sure what the ultimate plan is for this machine. Right now it's a lathe and it's not getting a facelift, but that's probably going to change somewhere down the road. I will, however, put your name in with the paperwork, and if I decide to sell it off I'll give you first crack at it.
Thanks guys!
Can I have 'crack 2'?:)
Cavediver
Post by Cavediver »
You certainly can.
It's likely I'll keep it with the machine, but I'll get in touch if I change my mind.
dgale
Post by dgale »
Cavediver wrote:You certainly can.
Soak it in some evaporust and it should clean up nicely
dgale wrote:Soak it in some evaporust and it should clean up nicely
Remove the aluminum knobs first!;)
heathicus
Post by heathicus »
I'm interested in how this performs compared to the more common and traditional table raising crank. I was under the impression this was more for "micro" type adjustments. Sort of the 10E/ER version of this: http://www.shopsmith.com/ownersite/cata ... collar.htm
Heath
Central Louisiana
Cavediver
Post by Cavediver »
I don't have one of those to compare to, so the best I can do is measure the amount of travel per revolution of the adjustment knob. I'd hazard a guess that the newer version is faster with less control, but it's just that: a guess.
Regarding the mechanism I have: what are the two ears with bolts for? Adjusting the angle of the extension bar? Also, any chance someone knows the thread pattern for the mounting bolt?
