What is this part?
What is this part?
This came with my two used shopsmiths. I haven't been able to identify it yet. Any ideas? It is about 4 x 5 x 7.5 inches.
Luckily it isn't a 'spare' part left over after I finish cleaning and reassembling the machines. I've had none of those.
Of course that might be because I haven't reached the reassembly stage just yet!
[ATTACH]24750[/ATTACH]
[ATTACH]24751[/ATTACH]
Thanks,
Fitzhugh
Thanks,
Fitzhugh
- unknown.jpg (197.44 KiB) Viewed 1417 times
- unknown2.jpg (99.01 KiB) Viewed 1411 times
- idcook
I’m a total newbie when it comes to recognition and name of parts, but this looks to me like a base for something. The hole with the thumbscrew insert seems designed specifically to hold a post that probably holds something intended to be movable, up and down, its length.
Of course I’m just guessing. What that might be for, or even if it is to be found among Shopsmith tools or parts, I cannot suggest.
I could be wrong but I think it might be part of a blade guard assembly (?) I'd have to wander out to the shop and look around and it's too late for that but I've seen that part before.
'82 Mark V 500 #96309
- RobertTaylor
part id
it is indeed a part of a blade guard. from an older 113.xxx series craftsman table saw.
- rcplaneguy
- idcook
Well, isn’t this quite the three pipe problem?
Specifically — Why is Shopsmith issuing Craftsman parts to its own customers?
My best guess (and likely the worst), is that packaging and shipping is conducted by some third party warehouse operation denizened by workers in the habit of tossing in the odd bit here and there based on habit due to lack of managerial oversight.
If not that, then I find it difficult to understand why Shopsmith would maintain a stock including any Craftsman part at all.
The original poster said his came with a used Shopsmith. It's very common for random parts from other equipment to wind up included with a used Shopsmith.idcook wrote:Well, isn’t this quite the three pipe problem?
Did the one you have come from Shopsmith? Or did you also get it with a used one?
Heath
Central Louisiana
Central Louisiana
Aha! That's the one, alright! Thank you for the detective work!
Idcook: I think it more likely it is just a kind of wild coincidence that two of us have them. I bought my shopsmiths from someone who has a basement with various stationary tools I gather he used more for repairing his large sailing boat and less for woodworking for the sake of woodworking and he could easily have just mixed it in by accident. Considering guards are often removed and craftsman is a common brand, and that this piece suit looks like a shopsmith part, I think it isn't as surprising as it first sounds.
I'll have to return it along with the parts to an aluminum audible framing square I also found in the box. Now, if only he has included the real upper guard...
Fitzhugh
Fitzhugh
