Bandsaw setup correctly=no blade drift!
I didn't believe that a bandsaw should not have blade drift until I found this way of setting up a bandsaw. I always believed all the "experts" about blade drift. I have set up three different bandsaws following this way of setting up the blades and have no drift on any machine or blade!
https://www.youtube.com/watch?v=wGbZqWac0jU
this should be taught in bandsaw 101
Just remember that there are differences with the SS bandsaw set up.
Yes, the Shopsmith bandsaw blade tracking adjustments are different than any other bandsaw but the tracking principles are the same. I am using the excellent instructions in the Shopsmith Forum posts for adjusting the bandsaw blade tracking starting on 08-05-2011 by JPG40504:
http://www.shopsmith.net/forums/showthr ... djustments
I find the instructions for adjusting the blade guide column post needs to be completely followed. I sometimes elongate the auto tracking screw hole in the mounting bracket to get the blade to very lightly track between the 2 lower guide bearings
- idcook
Gosh,
I love when you guys do stuff like this. JPGs bandsaw maintenance thread, including the various lines of discussion it engendered, clearly serves as an invaluable reference tool.
As someone in that thread suggests, I believe it’s high time I started printing threads of this kind and composing myself a handy "SS maintenance" binder.
beeg wrote:Just remember that there are differences with the SS bandsaw set up.
The difference is the rear blade guide. Makes the 'gullet' centering unnecessary. It also makes the lower blade back up adjustment to just touch the rear of the blade.(it guides the blade onto the lower wheel)
Every thing else is the same.(assuming upper wheel cant is correct)
IMHO he does a very good job there.
P.S. Oh yeah, there are those post adjustments. PITA, but critical! They insure consistency as the upper guide is moved vertically.
- rcplaneguy
teacherman
Re: Bandsaw setup correctly=no blade drift!
you guys are hilarious
gullet centering is critical. put the most tension right behind the blade. this give's your blade teeth a fighting chance at pointing the right direction when you shove a little work at em. no max tension @ center of blade behind gulletts, no talking about straight cut yet
