New to this forum - Just purchased a Mark V 510. Is there a lathe adapter for the Shopsmith to fit a morse taper? Have a pen mandrel & nova chuck and would like to use with the taper..
Thanks - James
Lathe adapter
Hi, Goofy! Welcome!
A #2 morse taper should fit nicely into the tailstock. If your chuck won't fit down to the mandrel tube, you can use Shopsmith's 1/4" router bit holder, (assuming your tube is 1/4"). http://www.shopsmith.com/ownersite/cata ... shield.htm
If you want to try it, you could try to hold the tube with a drill chuck. However I'm told the drill chuck is not designed to hold the twisting force of a router bit, so might be a problem holding the mandrel tube.
I was given a #2 morse taper mandrel with a "mandrel saver", so I had two #2s on one stick. Put the fixed #2 in my chuck and used the "mandrel saver" in the tail. http://www.pennstateind.com/store/PKMST ... odpage=1PK
Have fun!
Have fun!
- terrydowning
The SS will not accommodate MT2 in the head stock.
Options:
Option 1: Unscrew the mandrel from the MT2 taper and use either a drill chuck or as stated the 1/4" router adapter. I have used the drill chuck, it works fine, you should NOT be pressing into the mandrel so side loading a tiny spindle like a pen blank is not a problem.
Option 2: Visit Penn State Industries and purchase their mandrel with SS adapter. I also have one of these and it works well especially with an MT2 mandrel saver.
Options:
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
