I just got my 510 table carriage and set it up. But I can't get the table to go down more than a couple of inches. The gears line up it just stops right before poking out the bottom of the carriage. Nothing appears to be bent or twisted. Any help would be appreciated.
thanks
table carriage
Need a little more info to know how to help you, Scott. Test your carriage with the lathe tool rest post. Mount the post in the front carriage hole and crank it up and down. Do the same in the back carriage hole. If the lathe tool rest moves up and down smoothly, the problem is likely with the table assmebly. If it doesn't, the problem is likely with the carriage.
Was this one of our upgrade kits?
With all good wishes,
Nick Engler
http://www.workshopcompanion.com
I have had the blade guard get in the way of the table lowering because it was adjusted too far from the blade. I usually set mine about an inch out from the blade. I'm not sure what army1ret meant by cleaning and lubricating the blade guard. Will the table lower correctly when the head stock is not under it? If so, then be blade guard is probably the culprit.army1ret wrote:Gentlemen- I had the same thing happen to me. The problem for me was the blade guard. I cleaned it, lubed it and it works like a charm.
Good luck!
