Help Kit Question
Help Kit Question
The Help Kit is the Weekly Special right now.
Nothing has changed but I have a question. The Kit contains a 1/4"-20X2" Round Head Set Screw. Where is that used??
I sure wish I had been more observant back when all of this stuff I own first arrived. If I had been, I would not have so many questions today.
Would someone, please, post a picture of the 5/16"-18x3/8 motor pan screw with nylon locks. I think the motor pan most now attach differently than does mine. My headstock has clip-on nuts and no nylon locks.
[ATTACH]25502[/ATTACH]
clip on nut.png (8.22 KiB) Viewed 1336 times
dusty wrote:The Help Kit is the Weekly Special right now.
Nothing has changed but I have a question. The Kit contains a 1/4"-20X2" Round Head Set Screw. Where is that used?? Idler eccentric clamp?
Interesting that the motor pan screw is left handed.:rolleyes:
JPG40504 wrote:Interesting that the motor pan screw is left handed.:rolleyes:
Thank you. I just don't think of that as a set screw but then the table insert screws (flat head countersunk) are the same way. Guess I got tunnel vision.
Huh. Why do you say that?
dusty wrote:Huh. Why do you say that?
Look at your pix! What direction causes the screw to go further into the 'nut'.
No, the actual screws are NOT left handed.
I do not think of those 'other' screws as 'set' screws either.
This would be 'right' handed.
[ATTACH]25503[/ATTACH]
screw_tinnerman clip.jpg (10.08 KiB) Viewed 1317 times
JPG40504 wrote:This would be 'right' handed.
OKAY I understand now. Maybe I should write a note to the illustrator.:rolleyes:
Gene Howe
Post by Gene Howe »
Watching a movie on TV yesterday. A guy was taking DW screws out of a box lid with a cordless drill/screwdriver. The drill was in reverse, the screw was turning as if it were a left handed screw but it was obvious that it was not. Yet, amazingly, it came right out.
I had to stop the DVR and play it back in slow motion to see what I was missing.
Nothing.
Ain't Hollywood ingenious?
Now why couldn't they have eliminated the contrails from those Randolph Scott movies?
Gene
Gene Howe wrote:Watching a movie on TV yesterday. A guy was taking DW screws out of a box lid with a cordless drill/screwdriver. The drill was in reverse, the screw was turning as if it were a left handed screw but it was obvious that it was not. Yet, amazingly, it came right out.
Nothing.
The aliens would not cooperate.
Nothing.
Same reason the wagon/carriage wheels run backwards. Strobe effect of the shutter.;)
Contrails are another matter entirely.:D
I think today it would be possible.:rolleyes:
