Oval Sander
beatnik
Oval Sander
Post by beatnik »
Kind of hard to explain. Has anyone ever seen a benchtop or floorstanding type belt sander that is an oval ? Something like this Rigid, but curved instead of flat on the plate side.
http://www.rockler.com/how-to/ridgid-eb ... -assembly/
beatnik
Post by beatnik »
Probably not such a beast, but here's the reason I ask.
I have to build ovals sometimes and it would be nice to have a sander with more or less radius depending on the area of the work piece being shaped. This can be a pain when doing the inside of a frame piece and the small 3" drum works great in the tight areas, but a larger one would do better in the flatter parts. One that would cover both instances would be great.
Jack Wilson
Post by Jack Wilson »
With the belt on that unit, you would have two different size radius. Then with the different size drums, couldn't you sand all the parts.
Maybe I am misinterpreting what you are saying.
Jack
SS Mark 7 PowerPro, 2 SS Bandsaws, SS Belt Sander, SS Jigsaw, 13" Steel City Lunch Box Planer, SS Jointer, Jet 22-44 Drum Sander
beatnik
Post by beatnik »
Something like this with a curved plate on one side. Would allow simple transitions between different radius.
Jack Wilson
Well, now I understand, have not run across any thing like that.
beatnik wrote:Probably not such a beast, but here's the reason I ask.
Do you make several ovals of the same size? If yes, you could set up the drum sander to work like an overarm pin router. A guide "pin" (of the same diameter as your sanding drum) affixed to the table, a nice oval template, and you could sand perfect oval replicas all day long. I'm thinking that a drum-sander insert would make a dandy fixture to hold the "pin".
Same principal as routing with a pattern bit, except that the "pin" guides the cut, instead of the bearing on a pattern bit.
beatnik
Post by beatnik »
These are custom to fit different window openings. Seems everything I build is a one off piece when the need (customer) arises. Very rarely do I build two identical shapes.
If you have the Shopsmith belt sander, try sanding on the back side where there is no platen. CAREFUL -- the belt travels bottom to top.
beatnik
Post by beatnik »
I don't have the SS sander yet, but I would like a nice smooth transition. Here's a better picture of what I was hoping someone has made at some point ?
beatnik wrote:I don't have the SS sander yet, but I would like a nice smooth transition. Here's a better picture of what I was hoping someone has made at some point ?
I am missing something here! Why is this not a job for the drum sander mounted on the Mark V headstock in the drill press mode? Simply change drums if the curve so dictates.
