HF Dust Collector
michaelosburn
HF Dust Collector
Post by michaelosburn »
This looks like it might be worth the money. Only $185 with the coupon.
Here's the link: Just copy & paste into the address bar
http://www.harborfreight.com/2-hp-indus ... 012_c3314a
rcplaneguy
Post by rcplaneguy »
If I had the room I would put that one in, along with micron pleated filters and a tornado type separator. Many posts on youtube about the hf dust collector, nothing wrong with the motor or fan. You can get the price down to 160 with a 25% coupon.
John
STB
Dust Collection
Post by STB »
michaelosburn wrote:This looks like it might be worth the money. Only $185 with the coupon.
The link below is the latest video blog from the Stumpy Nubs workshop. Al tho the blog doesn't address HF directly you may find insight into your dust collection quest.
http://www.stumpynubs.com/snw45.html
Glenn
"Wild Bad Bob"
Post by "Wild Bad Bob" »
Stumpy,
nice info and site!! Thanks, of course added to the favorite list!! I guess I will be getting the canister filter for mine as an up grade this fall, when moving to basement shop.
Gene Howe
Post by Gene Howe »
If it's possible, you guys with HF collectors might consider dispensing with the bags and mobile mount and directing the dust outside.
With a cyclone ahead of the unit, there is a minuscule amount of dust that escapes.
Saves a ton of space, a ton of $$ otherwise spent on upgrading the filter, and a ton of time otherwise spent emptying the bag. Suction is noticeably better, too.
Gene
heathicus
Post by heathicus »
Gene Howe wrote:If it's possible, you guys with HF collectors might consider dispensing with the bags and mobile mount and directing the dust outside.
That's what I plan on doing whenever I manage to get one! Take the money I save on filters on put it into ducting.
Heath
Central Louisiana
"Wild Bad Bob"
good suggestion Gene!!
Remember that when blowing your dust outdoors, you are blowing a lot of air out along with it. And sucking an equal volume of outside air back into your shop. No problem for an unheated shop.
But if blowing heated air out and sucking freezing air back in, this could get expensive real fast. Ditto if running A/C on a hot day. I try to time my workroom exhaust fan use to coincide with moderate outdoor temps.
"Wild Bad Bob"
BD,
nice observation BUT in a 1 man shop in reality, some fresh air is good, how long is it actually running, when making a few cuts on the TS, BS, planer, jointer? Now doing some routering, or turning may be a bit longer, but better some fresh air return then some wood dust allergy. IMHO
robinson46176
Post by robinson46176 »
I have a HF collector (claimed 2 HP) and like it.
I intend to pipe mine directly outside from the basement shop and into a small wooded area north east of the house. Note that this a farm and I have no close neighbors. My only near neighbors are my son about 900' to the northwest and one of my daughters about 400' to the south.
I do have past experience with venting outside, summer and winter.
For now I am just using the stock bags and have no problem with them.
I also have a Penn State DC that is said to be a 1 1/2 HP. It is also a good unit and is running the stock bags.
