Finishing Up
gr8mesquite
Finishing Up
Post by gr8mesquite »
What is your preferred finish for turned bowls? What's your method for applying?
Thanks
Jerome
"Life is what happens to you while you're busy making other plans."
fredsheldon
Post by fredsheldon »
Here's how I did it. Not necessarly the best way but it worked for me.
http://www.shopsmith.net/forums/showpos ... stcount=99
Fred Sheldon
The Woodlands, Tx
farley
Post by farley »
not many replies
I use a wipe on poly after sanding to 400 max.
It gets it off the lathe so I can move on while the wait between coats happens.
some I use the beall system to.
