Just got home with SS #2. Very clean and the motor had been checked, inside housing cleaned and all lubed. Noisy when first fired up in 35* weather. After 30 seconds settled down to smooth and quiet. I received the owner's manual with this one. After advice from Mr. Mayo, I am going to make it a shorty. It will clear joists in the basement ceiling easily and it will see most use with jigsaw and strip sander mounted. That leaves tablesaw on #1 with 2000 Incra and Miter Express and Jointer most of the time. By the bye- the Incras virtually end the out of square issues for the table saw. They get pulled to rip- of course on # 2 I could also leave the table saw since I am set up on the right hand slot.
I doubt I will get any argument- having the two is really convenient but still retains the SS feeling of adaptability- bandsaw and belt sander.mt
SS #2 is At Home
SS #2 is At Home
1983 Mark V- beltsander, jigsaw, Stripsander,jointer, bandsaw-double carriage and tables with molders and drums, Over Arm Pin Routers(Freestanding x 2)Second Mark V.
- pinkiewerewolf
Congrats!
There really is no argument against having two Mark Vs in one home.
With so many SPTs offered, having two units allows a woodworker something of a production line.
You won't regret having a shorty in the work force either. I'm already using mine in some pretty creative ways, plus it is an effective in-feed and out-feed table that can match height and angle of the mark V that does the cutting.
Kudos again!
Kudos again!
John, aka. Pinkie. 1-520, 1-510 & a Shorty, OPR. 520 upgrade, Band Saw, Jig Saw, scroll saw, Jointer, Jointech Saw Train.
Delta Benchtop planer, Makita LS1016L 10" sliding compound miter saw, Trojan manf. (US Made)Miter saw work center, MiniMax MM16 bandsaw.
Squire of the Shopsmith. ...hmmmm, maybe knave, pawn, or wretch would be more appropriate for me.
