About three weeks ago, I bought a Shopsmith 10e (S/N 19186) for $100 off a Craig's List ad. Before dropping the cash, I read through MickeyD's entire 10er rebuild thread and was positively blown away not only by how we he detailed every step, but by all of the amazing support you guys provide. This forum is amazing.
I'm buttering you up because I need help. My plan is to completely refurbish the 10e, which, so far, has not been difficult. It has needed a lot of love, but it nowhere near the rusty shape I've seen others on here.
Step one has been to clean off the 60+ years of caked up grease and sawdust, which prevented the quill from turning among other things. I have disassembled the headstock and was even able to pop out the headstock pulley assembly. The bearings are super caked with gunk, and one of them feels a little tight. I'm trying to pop the pulley off the shaft so I can get to the bearings. But that pulley is on there TIGHT.
I already removed the set screw, so that's not it. I've completely deformed the pulley using a bearing puller and pulley puller trying to pry it off. I've drenched the thing in PB Blaster and the shaft has budged a good solid inch, but no more. The top of the shaft is not about 1/8th of an inch inside the pully. I'm now using a hammer and tap on it, but I"m concerned about damagin the shaft itself.
Any clues on how to get this damn pulley off the shaft? Not sure I'll need to do it on the motor but, if so, any tips for getting it off the shaft without deforming the pulley? I've tried both the three-arm pulley puller as well as the split bottom style bearing puller - both wildly deformed the pulley.
Help? Thanks!
Removing Headstock Pulley From Shaft
docricketts
- Bronze Member
