Smaller Table saw arbor available?
ddub
Post by ddub »
My shopsmith has a fairly large (1 1/4?) arbor for the table saw blade.
Is there a arbor available that fits arbor holes of 5/8 diameter?
I glanced at the shopsmith website, but I could have easily missed it. I want to use a different style blade than what shopsmith has available. I want to cut plastic.
Thanks in advance!
Jack Wilson
Post by Jack Wilson »
Look on this web page, scroll down and you should find it.
http://www.shopsmith.com/ownersite/cata ... arbors.htm
SS Mark 7 PowerPro, 2 SS Bandsaws, SS Belt Sander, SS Jigsaw, 13" Steel City Lunch Box Planer, SS Jointer, Jet 22-44 Drum Sander
ddub
Post by ddub »
I figured they had to have one.
THANK YOU!
ddub
Post by ddub »
Ok,
I went to order one. The 500 is different than the 505, 510, 520.
I know I do not have a 510 or 520.
What is the difference between the 500 and the 505?
ddub
Post by ddub »
On this page they show inserts.
http://www.shopsmith.com/ownersite/cata ... nserts.htm
So, if I read between the lines, if both sides of my insert are rounded, I have a 500. Correct? Which I think they are, but I will verify at the shop today.
wodnek
Post by wodnek »
A trick i have used in my compound miter saw, is to use a high tooth blade and put it in backwards to cut plastic. I have had pretty good results. (actually used for vinyl siding)
The sickness is spreading:
Mark V greenie 1954
Mark V goldie 1962 (I think)
Mark V grey 1978
Shopsmith attachments: 2 Jig Saws, Bandsaw, Jointer, Planer. Shaper tooling, many adapters, arbors, etc.
50s vintage Craftsman table saw
50s vintage Craftsman band saw
ddub
Post by ddub »
I picked up a new freud plastic blade.
But it doesn't fit my arbor:rolleyes:
so I want to use the Darn thing!! :eek:
Sometimes the blade that I have does "OK", but sometimes it grabs the material and takes a chunk out of it. Minimum ruins my cut, maximum, probably not safe.
It is a fairly fine blade, I didn't try it backwards but I guess I just want to spend more money on the adapter. LOL
Since I cut a fair amount of polycarbonate, (more than wood) I am ok with using the proper stuff.
ddub wrote:Ok,
The 505, 510, 520 main tables are the same. The fences and rails vary(505 = 510). A 500 fence has a single 'knurled' knob that tightens the fence to the table/rail.
wodnek
Post by wodnek »
I do have about a 2.5 inch long arbor that my craftsman dado blade fits that i use on my shopsmith, so one does exist, its a shopsmith part.
Mark V greenie 1954
Mark V grey 1978
ddub
Post by ddub »
&quot wrote:The 505, 510, 520 main tables are the same. The fences and rails vary(505 = 510). A 500 fence has a single 'knurled' knob that tightens the fence to the table/rail.
Then why do they say the blade arbor is different?
My insert is rounded on both ends, so I am going to order the 500 unit. They state that stock is low. We shall see.
