http://en.wikipedia.org/wiki/Ultra-high-molecular-weight_polyethylene
"Wild Bad Bob"
Post by "Wild Bad Bob" »
I needed to make some "fittings/spacers" for my Delta saw fence tube to table supports, first I made them out of ash wood, my screw up, grain the wrong way and split under pressure, then bought a sheet of 3/4", 12"x12" UHMW, machines like wood, made the strip I needed, and whala!!
&quot wrote:I needed to make some "fittings/spacers" for my Delta saw fence tube to table supports, first I made them out of ash wood, my screw up, grain the wrong way and split under pressure, then bought a sheet of 3/4", 12"x12" UHMW, machines like wood, made the strip I needed, and whala!!
It will 'compress' under pressure, so keep the gorilla locked up.;)
"Wild Bad Bob"
Thanks JPG, on that, never used it b4, and yes it will be under compression, not jut a fancy face on a fence!!!
Just got off the tellie with Steve/Skou, talken 10s!!!!
Do you have one???
&quot wrote:Thanks JPG, on that, never used it b4, and yes it will be under compression, not jut a fancy face on a fence!!!
Do you have one???
My 'Blue Beast' is inpieces awaiting reassembly. Check my sig line.;)
