Gilmer Drive Clutch
mdriver
Gilmer Drive Clutch
Post by mdriver »
I am cleaning up my clutch/shaft before adding new bearings and noticed from an previous post by mickyd https://forum.shopsmith.com/viewtopic.php?p=32871#post32871 that his washer layout is reversed from the way mine came apart.
Great post of information BTW!!
Please see my pictures at:
https://www.dropbox.com/sh/rwh0rt7grcpr7lz/AADSyRfSDRSRzgcYT-41WOp2a?dl=0
I'm not disputing his opinion (or great work) but just wish to know what other folks have come across. I have no idea if someone tore apart mine and reassembled in the wrong order. I do know this is how it came apart.
Missing from picture:
the fitted "condom" on spline shaft end but is stored in a zip-loc bag on workbench.
Please advise.
Thanks,
Mark Driver
rpd
Post by rpd »
It has been several years since I rebuilt the Gilmer clutch on my Greenie but I don't think reversing the order will make any difference.
I rubbed all the plates on a sheet of 1000 grit sandpaper to clean them up, removed rust from the metal plates and slightly roughened the fiber plates.
After I had it reassembled and tested the torque, it passed:), I discovered one of the fiber plates sitting on the bench:o.
This leads me to believe that the design is quite forgiving.:cool:
mdriver
Post by mdriver »
Thanks. After looking at it deeper I agree. As long as the disks can slip it's all good.
The torque test should reveal a slip action (by way of shaft rotating inside clutch housing) or a click feel at 10 -20 ft-lbs?
Thanks
