Mark VII upper assembly
First step is to place the lower tubes in the base.
[ATTACH]26543[/ATTACH]
The right endcap goes onto the two tubes. They bottom out in the endcap bores.
[ATTACH]26544[/ATTACH]
The tubes are secured by two set screws from the under side of the endcap.
[ATTACH]26545[/ATTACH]
The rear way tube is inserted into the right endcap and secured with a set screw on the top side of the endcap.
[ATTACH]26546[/ATTACH]
Next the carriage is slid onto the rear way tube from the left.
[ATTACH]26547[/ATTACH]
This thread is linked to from https://forum.shopsmith.com/viewtopic.php?t=11984
bench tubes 1.jpg (307.56 KiB) Viewed 6707 times
right end cap 2.jpg (1008.77 KiB) Viewed 6711 times
end cap set screws 3.jpg (231.42 KiB) Viewed 6708 times
rear way tube 4.jpg (314.29 KiB) Viewed 6709 times
carriage 5.jpg (592.92 KiB) Viewed 6709 times
Next the front way tube is inserted through the carriage and into the right endcap. Set screw is tightened after next step.
[ATTACH]26548[/ATTACH]
The way tube must be rotated to center the gear rack in the slot.
[ATTACH]26549[/ATTACH]
The table is inserted into the carriage and the table is 'lowered' against a block so the table posts supports the way tubes.
[ATTACH]26550[/ATTACH]
The headstock is 'slipped' onto the way tubes. This is not easy since that headstock is heavier than a Mark 5/V. Also the gear adds another thing to 'align' in addition to the headstock clamps. Fortunately these are visible from the outboard end.
[ATTACH]26551[/ATTACH]
The headstock rack clearance is checked.
[ATTACH]26552[/ATTACH]
front way tube 6.jpg (298.01 KiB) Viewed 6708 times
centering rack to carriage 7.jpg (465.09 KiB) Viewed 6708 times
add table prop 8.jpg (704.72 KiB) Viewed 6708 times
add headstock 9.jpg (545.58 KiB) Viewed 6707 times
headstock rack 10.jpg (659.12 KiB) Viewed 6706 times
The left endcap goes on next. This proved more difficult than the headstock. All tubes are the same length, so the tubes must line up(all 4 at once).
The endcap is pressed to bottoming out in the endcap bores. the set screws are tightened.
And raised to vertical right(drill press). This thing is really difficult to raise with the headstock all the way to the left(high in drill press position). The headstock is heavier, and the pivot is closer. The table etc' are lower than a Mark 5/V.
[ATTACH]26553[/ATTACH]
Drill press close up.
[ATTACH]26554[/ATTACH]
Raised to vertical left(shaper mode).
[ATTACH]26555[/ATTACH]
Finally a more 'traditional' setup.
[ATTACH]26556[/ATTACH]
The carriage lock has not yet been adjusted(nor a lot of other things).
left end cap 11.jpg (660.96 KiB) Viewed 6703 times
drill press 12.jpg (632.55 KiB) Viewed 6696 times
shaper vert 13.jpg (645.13 KiB) Viewed 6698 times
normal position 14.jpg (608.43 KiB) Viewed 6695 times
rjent
Post by rjent »
I don't know if I should post in this, and I will delete it if I need to, but why did the Shopsmith simply not continue in this design? It seems with the geared headstock, reversing motor, and double tilt, it was way ahead of, and superior to, the Mark V at the time.
Just curious.
Dick
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
rjent wrote:I don't know if I should post in this, and I will delete it if I need to, but why did the Shopsmith simply not continue in this design? It seems with the geared headstock, reversing motor, and double tilt, it was way ahead of, and superior to, the Mark V at the time.
Just curious.
Dick
I do not know. It has a bunch of stuff that reappeared in the 505/510/520 upgrade.
Also there are those two design flaws made of nylon.(cam, gear rack)
The headstock is much more complicated and the base requires more assembly.
And we do not know if the Mark VII trademark and tooling came from Magna American to SS Inc.. And the production documentation?
This is as good a place to raise the question as any. The intended stuff for this thread is 'done'. Sorry I do not have the answer, just conjecture;).
algale
Post by algale »
Looking good in Gold! All these machines look better, IMO, with the two tone vintage color schemes (Green or Gold).
bell
Mark V11
Post by bell »
I just finished looking at your post on the restoration. This one and your related ones of teardown. For me this is the first Mark V11 that I have looked at. I have owned and used my 510 since 1987 and have never looked at one of these. You have really done a good job. You wrote the book ! Did you work for Shopsmith ? How did you learn all of the procedures ? I also have wondered why the gear for headstock movement was not carried over to the Mark V. Thank you for the class. Ron
Re: Mark V11
bell wrote:I just finished looking at your post on the restoration. This one and your related ones of teardown. For me this is the first Mark V11 that I have looked at. I have owned and used my 510 since 1987 and have never looked at one of these. You have really done a good job. You wrote the book ! Did you work for Shopsmith ? How did you learn all of the procedures ? I also have wondered why the gear for headstock movement was not carried over to the Mark V. Thank you for the class. Ron
Grossly tardy responding, but here goes.
I did not work for SS(or predecessors).
I am a stubborn old fart who has always tried to figure things out by myself. Not always successful, but I learn from trying. I do try to find out before 'exploring'. In this case I was pretty much left to my own resources(analytical and deductive thinking). As such it is prone to being mis guided!
Realize the Mark 5 preceded the Mark VII. The Mark V 500 is the same design as the Mark 5 with few alterations/'upgrades'.
Re: Mark VII upper assembly
nice lookin' Honda, Red! :D
charlese wrote:nice lookin' Honda, Red! :D
Neighbor's trash containers are pretty also! :D
