Edge Banding
Edge Banding
Is anyone here doing edge banding on a small scale? What method do you use?
I see machines such as this one at Rockler
http://www.rockler.com/edge-banding-machine
Or is it just as easy and less expensive to use an iron such as
http://www.rockler.com/edgebanding-iron
Any advice would be appreciated regarding equipment, method, and banding material.
Jim
Jim
Hello from Somerset in the beautiful Pennsylvania Laurel Highlands.
Mark 7, Mark VII, Mark V 520, Mark V 510 x 2, Mark V 500
SPT's - Band Saw, Jig Saw, Belt Sander, Jointer, strip sander, Oscillating Sander, Speed Increaser
SS Freestanding - Pro Planer, Scroll Saw, Overarm Pin Router, Power Station, DC3000 x 2
Made for SS - Incra iBox, Ring Master
"Honest dear, I can quit any time I want."
A travel iron like this one is a lot less expensive and does the job very well. I use an old steam iron that my wife generously gave me.
You can buy a 250' roll of maple, oak or birch banding at Amazon or, smaller lengths at Lowes. Lowes may have other species, also.
Gene
Sorry, can't help much. The only edge banding I ever used was for an "small animal cage". It was made from pvc covered hardboard. Edge banding was also pvc with glue side. Applied sticky side down, rolled and trimmed. Rollers and trimmers are available for not much $.
When using plywood, I have made edges from wood, and glued in place. I've used 1/8" and 1/4" banding for exposed edges. The only trick here is to cut the plywood the appropriate distance smaller to allow space for the edge wood.
Another cheap (maybe $10) clothes iron user here. I've probably done 100 or so feet using one on a few projects. I put it on the highest setting, keep it moving, pressing down firmly, then put a length of board on top of the banding and give a few whacks with a small deadblow mallet.
Roy
Home designed and built CNC router, another CNC router
desktop size, Avid 5x10 Pro CNC w/ATC, CNCed G0704 milling machine
Laser engraver
Way too much other stuff and not enough space
Laser engraver
I stopped in a resale shop this morning and they had 6 different irons for $5 apiece. Lady said they all worked, too. Didn't buy any because my old wifes, still works.
Gene
I do hope you are referring to your wife's old iron and not your old wife's iron.Gene Howe wrote:I stopped in a resale shop this morning and they had 6 different irons for $5 apiece. Lady said they all worked, too. Didn't buy any because my old wifes, still works.![]()
I picked up an iron at the Salvation Army today. Bonnie took one look, decided it was better than hers, and offered a batch of cookies, and her iron in trade. Works for me
