I needed to resaw some 3 x 5 inch sappele. I mounted my 5/8 blade, tensioned it up to the recommended 1/2, set my Kreg fence (which i had previously adjusted to this blade) and started up. The work pulled away from the fence and the cut was bowed. Stock ruined.
I stripped everything down, checked and recalibrated the tension gauge, checked and adjusted the autorack bearing, checked readjusted the upper back up bearing, checked and adjusted cool blocks. Checked wheel cant. All good.
Remounted the blade. It is riding properly in the autotrack bearing groove. It is riding against the lower back up bearing. There is the recommended 1/64 space between the back of the blade and the upper back up bearing. All good. All is as it should be.
Except one thing: the blade is at an angle where it goes through the table insert. The front of the blade (teeth) point left and the rear of the blade points to the right! The angle is such that there's not enough play in the trunnion brackets to allow the table to be set up with the miter slot parallel to the blade.
I remember another user had this problem with this blade and I don't think we ever got him straightened out (literally or figuratively).
Called Shopsmith and described my problem. Checked the blade weld and back of blade. All good. They suggested first increasing upper wheel cant (no effect) and then reducing upper wheel cant. Reducing the upper wheel cant has reduced the angle of the blade to where I can adjust the table so the miter slot is parallel to the table.
Readjusted the Kreg fence for drift and tried to resaw some scrap. Same problems. Work is pulled away from fence after the cut and the blade is bowing. And cuts using the miter gauge are drifting too.
I will try mounting the blade in my recently acquired older vintage Shopsmith band saw and see if it is a problem on that band saw too. I will also try mounting some smaller blade in both saws and see what gives.
At the moment I am at a loss and very frustrated.
