Bandsaw Metal Cutting Blade
Lodgepole
Post by Lodgepole »
I need to cut 1/4" thick brass to make a new bale pull.
I have found only one source, Mark's Tool's, on the internet. Does anyone else know of any other sources?
Thanks in advance for any ideas.
Lodgepole wrote:I need to cut 1/4" thick brass to make a new bale pull.
Shopsmith lists bandsaw blades to cut non-ferrous metals. I have used them successfully to cut aluminum though nothing 1/4" thick.
In aluminum, the blades do tend to clog. I don't think that would happen in brass.
Lodgepole
Post by Lodgepole »
As always, Dust, Thanks!
Jack Wilson
Post by Jack Wilson »
SS Mark 7 PowerPro, 2 SS Bandsaws, SS Belt Sander, SS Jigsaw, 13" Steel City Lunch Box Planer, SS Jointer, Jet 22-44 Drum Sander
lightnin
Post by lightnin »
Timberwolf has a good selection
Bruce
Ok Ok, I'm up to four now...
Lodgepole
Post by Lodgepole »
Thanks for listing these other vendors.
CNCFan
Re: Bandsaw Metal Cutting Blade
Post by CNCFan »
You can try a CNC Plasma Table http://arclightcnc.com - they are great at making clean and accurate cuts through any type of metal. I don't know if you want to purchase one as they can be a little expensive, but if you are going to be cutting metal on a regular basis I highly recommend one. These can be set up in your garage or shop and come in a variety of sizes.
Lodgepole
Post by Lodgepole »
Thanks for the idea, but this is a single metal working project. But, who knows what projects I may try in the future!
CNCPilot
Post by CNCPilot »
Her'e another CNC table that I've used and love Link deleted by Moderator
Might not be what you are looking for but good for someone else with he same kind of project.
CNCPilot
Post by CNCPilot »
I'm sorry. I see this is from 2014 and you didn't need a table. Just trying to help. :)
