Setscrews - Used in Shopsmith Equipment
Over the last few weeks I have received requests to transmit or retransmit a spreadsheet detailing information on the setscrews used in the Shopsmith equipment.
The information contained in my latest version of this spreadsheet is essentially the same as before. I have added some color coding to 1) Identify Part numbers used in multiple locations and 2) Identify those parts that are included in the Help Kit (515325).
Shopsmith Setscrews Version 10.doc
(104.5 KiB) Downloaded 775 times
Re: Setscrews - Used in Shopsmith Equipment
And for fellow µsoft haters:
Shopsmith Setscrews Version 10.pdf
(67.85 KiB) Downloaded 626 times
Well at least the important part is there!
Thanks, Dusty. I've salted it away in my Mark V maintenance folder.
And here's a PDF copy showing the full comment and item quantities.
(21.84 KiB) Downloaded 665 times
algale
Post by algale »
This looks very useful and should be among the stickies in maintenance. Thank you, Dusty, for taking the time to make this and share it.
That is an improvement over my feeble attempt! procedure???
rpd
Post by rpd »
JPG wrote:That is an improvement over my feeble attempt! procedure???
When you open Dustys file in your spreadsheet program, select all, change font size from 10 to 7.
What 'spreadsheet' program???
It is a doc file.
Is my ignorance showing????
Thanks Dusty!
I had the file from a previous post of yours and was looking for it without much success so it was nice to see it posted here again. Made a print this time to put in my manual.
If you find any errors (all who read this), please post them here on the forum so that everyone can make appropriate corrections.
rpd
Post by rpd »
JPG wrote:What 'spreadsheet' program???
It is a doc file.
My mistake :o , it opened in LibreOfficeWriter, I thought it was in LibreOfficeCalc.
So what ever word processor you open the file in part of the last column is cut off,
[img]
As downloaded   font size = 10
[/img]
if you reduce the font size all of the text will show. :)
[img]
font size reduced to 7.
font size7.png (207.97 KiB) Viewed 3740 times
[/img]
