lathe chisels
lathe chisels
I have a new Mark 7 that I am getting to know. I am excited to begin turning a few things, but have limited experience. I want to purchase some lathe chisels. Shopsmith is currently having a sale on a set of carbide chisels made by Easy Wood Tools. They are not typical looking chisels, but claim to be easier to use and you never sharpen them.
Question: Should I consider these or stick with the "regular" type lathe chisels for my first set?
Thanks
Thanks
Re: lathe chisels
Might I suggest that you look here for a local chapter of a woodturning club.
http://www.woodturner.org/search/custom.asp?id=1509
Re: lathe chisels
Ditto what beeg said. Having a coach while you are learning is priceless. I have some Easy Wood tools. I like them. They are easier to learn. However, I get more tearout than with standard tools. I also find them sometimes catchy if i have a muscle tremor.
Re: lathe chisels
I use the Easy Wood Tools and they are exactly that, easy. However, they do in fact leave a rougher finish than the conventional lathe tools. They give the novice turner a good sense of accomplishment due to their shorter learning curve.
Can you tell us where you are located? Do what Beeg suggested and see if you can link up with a mentor.
Turning is a woodworking activity that has a smaller following than most other woodworking activities but that following tends to be rather fanatical.
Therefore, I am a fanatic.
I like my EWT tools but I still try to master the conventional ones.
Re: lathe chisels
Thanks for the replies. I tried finding a local turning group on the suggested website, but no luck. I am in the Southern Ohio area.
The sale on the chisels ends in a couple of days, so maybe I should take a little more time to evaluate....
The regular chisels are definitely less expensive but I was intrigued by the EWT pitch and offer...
Re: lathe chisels
JTD7366 wrote:Thanks for the replies. I tried finding a local turning group on the suggested website, but no luck. I am in the Southern Ohio area.
Do support your neighboring state to the south's producers.
Since they are 'scrapers', using them is easier for a novice.
- ChrisNeilan
Re: lathe chisels
I mainly turn. I have a few carbide tools and think that they're great, but not the end all. Use them to get close to the shape you want and finish off with traditional SHARP tools. The difference is tremendous, but only comes with practice. Find a club if you can. I wish that there was one near me (closest is about 60 miles away), but alas I had to settle for Youtube as my club! Make sure that you have a face shield and that you use it!
Re: lathe chisels
Thanks Chris. Think I'll start with the regular set of chisels and go from there. ...yes, youtube is great....
Thanks for the reminder on the eye protection...
Re: lathe chisels
Like others have said, YouTube IS the answer.
Check out this channel, Eddie is recovering from
some brain surgery, and WILL return, but his stuff
has taught me TONS. Mainly, "ride the bevel."
https://www.youtube.com/user/capneddie
Go back to the "less than 100 posts" area, and start
watching. As Eddie would say, "All you gotta do is
WATCH!"
steve
WATCH!"
steve
10 ER, stripped down.
Re: lathe chisels
Are you near Cincinnati? http://www.woodturner.org/members/?id=23094121
Roy
Home designed and built CNC router, another CNC router
desktop size, Avid 5x10 Pro CNC w/ATC, CNCed G0704 milling machine
Laser engraver
Way too much other stuff and not enough space
Laser engraver
