Is there a search engine available that will return nothing, I mean nothing, if it has nothing that you are searching for. Do they all pretend to know more about what I want than I do.
I have been searching for a specific item, by part number and/or description, and I get returns but all of them are for something other than what I searched for.
Search Engine
Search Engine
- Shopsmith Adjustable Dado, AK-0590
Especially good for cutting dadoes to match thin plywood dimensions. - Shopsmith Adjustable Dado 001 (Small).jpg (70.37 KiB) Viewed 1772 times
Re: Search Engine
Dusty;
Are you referring to this site or search engines in general. If I search for something but not on this site I get an answer, but the answer directs me to another search engine like "wow.com" or some other.
Most search engines take your input and tries to match words.
If your search term does not match exactly the terms used by the company then the search will match any word that you used for your search.
Kind of like covering all bases.
Re: Search Engine
I have been searching outside of this site.
I have searched for several combinations of the string "Shopsmith Adjustable Dado Blade AK-0590".
I have been using this only as a learning situation. The dado blade is just an "item to search for" that I know for certain exists. It seems to me that I must not be using the search engines properly or one of them would return something. I have gotten some returns that send me back to the Shopsmith sites (catalog or here) but there must be others.
- rjent
Re: Search Engine
Dusty, sometimes putting pertinent words in quotes (" ") will return better performance. Using something like "AK-0590" + "shopsmith" + "dado" will return better results than just typing in AK-0590 shopsmith dado.
Now, if the item you are looking for is rare, the search engines will not have a lot of pertinent info on the item and return a "best guess" result which can be amusing at times.
Take one of your electronic devices (TV, Stereo, etc) take the model number and do a search for it. It will come back with surprisingly accurate, returns, however I searched for your wobble blade and it didn't return much.
Just a FWIW moment
Just a FWIW moment
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
1951 jigsaw X 2
Re: Search Engine
Yes, I have had some of those amusing and sometimes scary returns. Sometimes returns that I don't even want on my computer. There are words that I will not even think about putting in a search. Words like taliban, etc, etc. quotes or no quotes, not ever.rjent wrote:Dusty, sometimes putting pertinent words in quotes (" ") will return better performance. Using something like "AK-0590" + "shopsmith" + "dado" will return better results than just typing in AK-0590 shopsmith dado.
Just a FWIW moment
Re: Search Engine
I am curious, BTW, about who made that adjustable dado for Shopsmith. Just like I am curious about who makes the blades that they are now selling. When Amana Blades went away, who replaced them? Just curious. Sorta like to know what I am buying, even when I am buying from Shopsmith.
Re: Search Engine
I believe that the original stacked dado was by Vermont American.
Re: Search Engine
Vermont American is a very likely candidate, if not for mine then for Charlese and maybe for both. It appears from the postings that we both acquired our blades in same general time frame.
