1. If you connect two DC3300's via y pipe, will it result in twice the cfm provided by one DC3300?
2. Does adding a Dust Deputy reduce the cfm of a collection system?
3. Is there a difference in cfm between using the corrugated hose or PVC pipe to construct a DC system?
DC Questions
DC Questions
Hello from Somerset in the beautiful Pennsylvania Laurel Highlands.
Mark 7, Mark VII, Mark V 520, Mark V 510 x 2, Mark V 500
SPT's - Band Saw, Jig Saw, Belt Sander, Jointer, strip sander, Oscillating Sander, Speed Increaser
SS Freestanding - Pro Planer, Scroll Saw, Overarm Pin Router, Power Station, DC3000 x 2
Made for SS - Incra iBox, Ring Master
"Honest dear, I can quit any time I want."
Re: DC Questions
My observation is that when I tried to put a Dust Deputy in line with my DC3300 that my 42 inch hood was less inflated which I attribute to less CFM.kablerj wrote:1. If you connect two DC3300's via y pipe, will it result in twice the cfm provided by one DC3300?
- rjent
Re: DC Questions
First question, it should. Make sure your "system" can handle the CFM
Third question: PVC will greatly be more efficient because of the turbulence drag that the corrugated hose creates ...
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
1951 jigsaw X 2
Re: DC Questions
Before I built my dedicated shop with a Clearvue Max cyclone I had a JDS 1 1/2HP dust collector with a pleated filter and not a filter bag. At one point I added a trash can with a separator lid. That is pretty much like what a Dust Deputy does. I eventually removed it because I thought it affected the efficiency (CFM) of the system.kablerj wrote:1. If you connect two DC3300's via y pipe, will it result in twice the cfm provided by one DC3300?
