Edge Banding
bn3022
Edge Banding
Post by bn3022 »
I'm building a medicine cabinet out of birch veneer ply with 1/4" thick solid birch banded edges. I made the banding slightly oversize as far as width goes. I can hand plane and sand the outside even as this won't be seen when finished. The inside is a lot more tedious for fear of cutting through the veneer.
Is there an easier way? I know I can try a flush trim bit in a router but the veneer thing could still be an issue and it doesn't go all the way at the inside corners. I've been using a block plane and a sharp chisel and some light sandpaper so far with OK results.
I know this subject was probably delt with on another thread somewhere but couldn't find it.
Ken
Re: Edge Banding
I wish I could help but you have already stated the only two ways I know to do this. I would be using a flush trim bit in a small router. I say a small router because I believe you have better control. Actually, a trim router would be best.
Re: Edge Banding
Can you apply the banding to the individual panels, and trim it to size before assembling the cabinet? If so, that would take care of the inside-corner issue.
Another thought would be to temporarily apply a strip of tape to the veneer, where the router-bit bearing will ride. That would leave the banding proud of the veneer just a few thousandths, after routing. It could then be taken down flush with very light sanding or planing.
lyall
Re: Edge Banding
Post by lyall »
if you have a lot to do you and make one like this guy made
http://www.ibuildit.ca/Workshop%20Proje ... mer-1.html
Re: Edge Banding
lyall wrote:if you have a lot to do you and make one like this guy made
Hi, Ken! You can do the same operation with your Shopsmith. It's call horizontal boring mode. You'll need a 1/4" or 1/2" router bit chuck. If you had a PowerPro this would be slicker. Better yet if you had a Overarm Pin router attachment it would be a breeze.
It will work with a standard headstock. Here's what you will need; http://www.shopsmith.com/ownersite/item ... tem=514632
Try it first with a scrap board and a glued on 1/4" banding.
bn3022
Re: Edge Banding
Post by bn3022 »
:) Thanks for the help. I like the tape idea and I should have taken care of the banding before starting any assembly. That alone makes life easier.
Ken
bn3022
Re: Edge Banding
Post by bn3022 »
Charles's,
Thanks for the video on the edge banding set up. That's the slickest and simplest I've seen so far.
I get the horizontal boring arrangement with the SS. I'd just have to raise or lower the table to adjust for the plywood thickness. Great idea. I think I,ll order the router chuck. It could be handy for a lot of things. My old 1956 greenie came with the shaper fence, bit chuck, some collars and a few bits that I'd like to try out as well.
Having fun,
Ken
Re: Edge Banding
And with a tilting table(reverse from 'normal') you get the adjustable angle bias as well. Note the need for a trough on the down side.
Re: Edge Banding
Ken:
You're welcome for any input I submitted, but the router video came from lyall.
Best Wishes!
