When is a 510 NOT a 510
everettdavis
Re: When is a 510 NOT a 510
Post by everettdavis »
It's suffering from an identity crisis, and amnesia is not part of the equation unless he visited Dr. Frankenstein's castle workshop.
rpd
Post by rpd »
Item18. Mark V 520 upgrade table system :cool:
Seller assumes all responsibility for this listing.
Item specifics
Condition:
Used: An item that has been used previously. The item may have some signs of cosmetic wear, but is fully ... Read more
about the condition
Power Source: Corded Electric
Model:
Mark V Model 510
Brand:
Shopsmith
Country/Region of Manufacture: United States
Up for auction is a used Shopsmith Mark V Model 510 shop tool that is great because it does so many different kinds of wood working on one machine. The base unit is equipped with retractable casters for easy moving and stability when in use. A complete owners manual is included. This is a one owner used Shopsmith. This machine helps you do the following work and has the accessories to do so. Rip saw; Lathe; Drill press; Miter cuts; Sanding; boring machine; biscuit joiner; etc. etc.
1. Rip saw with 10 inch blades (inc. extra blades) and saw guard. 2. Large 12" disk sander. 3. Safety tools - Push stick, Push block, Fence straddler and Feather board.
4. Electrical cord for ordinary standard plug-in. 5. Drill press 6. Miter gauge 7. Tailstock 8. Coupling kit
9. Allen wrenches and Arbor wrench 10. Lathe drive center 11. Lathe cup center 12. Lathe tool rest 13. Rip fence
14. Lower saw guard and shields 15. 1 1/4" saw blade arbor 16. Biscuit Joiner 17. 5/8" molder / dado arbor
18. Mark V 520 upgrade table system 19. 2 upgrade table extensions 20. 5/8" arbor 21. Vacuum hose connector
22. Drill chuck for the press
No shipping on this unit. Local pick-up only. Hope you live fairly close to Orlando. This machine is 35 minutes north on I4 near Deland.
rpd wrote:Item18. Mark V 520 upgrade table system :cool:
Item specifics
Condition:
about the condition
Model:
Mark V Model 510
Brand:
Shopsmith
Which makes it now a 520.
I think the seller is missing the boat by listing it as a 510 in the 'title'.
