I looked for this thread in anticipation of reassembling the base and 'discovered' I never created it.
I did take all the pix and had them ready to post.
So a bit tardy, but here goes.
Rear panel removed first. Two plastic knob screws.
Next the front panel. Secured with 'normal' screws.
Front and back screws use tinnerman 'nuts'.
Next the tilt support bracket. There are screws attaching it to the side also. The larger screws on top, the smaller ones on the side.
Top screws.
The vertical clamp mounts with a screw that includes a spring washer.
Clamp with screw etc.
From the bottom, the side retaining screws.
Screws out.
The end caps have two teeny screws securing the top.
End of first post
This thread is linked to from http://www.shopsmith.com/ss_forum/viewtopic.php?t=11373
MARK VII BASE ASSEMBLY BREAKDOWN
Re: MARK VII BASE ASSEMBLY BREAKDOWN
This shows how teeny the screws are.
Vertical 'stop' screws. The end caps rest on these when tilted to vertical(both ends).
The tension pin is driven out of the foot pedal and cam shaft.
Pedal removed.
This is not at all like a Mark 5/V.
Six screws attach the 'box' and 4 secure the piston bore 'plate'. The 'box' is part of the end with feet.
Tinnerman clips serve as 'nuts' for those six screws.
Clips, plate and caster removed.
Piston has a lip on top, caster retains it from below.
Cams are secured to camshaft with half dog set screws. Notice locating holes in shaft.
Pedal removed.
- cam hd set screw shaft 20.jpg (427.03 KiB) Viewed 3425 times
End/legs are the worst rusted parts.
Last base rail. Kept the rails temporarily attached to the base 'box' ends to raise them up for disassembling the previous 'stuff'.
Last a pix of all the 'hardware' holding this beast together.
The vertical clamp pivot/mounting screw,spring washer and nut seem to be missing from the pix.
For those who 'care' about Mark VII stuff, the base breakdown thread is 'finished'. All parts have been primed and after painting, the reassembly thread for the base will be created.
The end is near!!
The end is near!!
