10E Long or Short Base?
e2512
Post by e2512 »
I'm now in a rush to get my 10E, serial number 2512, restored. I noticed tonight that it has the shorter base with it. I'm thinking that with a serial number that low it should have the longer base.
Does anyone have a Model E with a close serial number that can confirm this?
Thanks, Tom
Re: 10E Long or Short Base?
e2512 wrote:I'm now in a rush to get my 10E, serial number 2512, restored. I noticed tonight that it has the shorter base with it. I'm thinking that with a serial number that low it should have the longer base.
Thanks, Tom
What do you mean by 'shorter' base? The hinge end had two different 'shapes' and the headrest had both two hole and 4 hole versions as well as both CI and aluminum. My 10E has the CI 4 hole headrest. I do not think the hinge end had a different mounting hole spacing, but mine has a round outer shape.
I would expect yours to also have the CI 4 hole headrest and the same hinge end. My SN is 3779.
e2512
Post by e2512 »
I didn't explain that very well.
By "Base" I mean the end that flips, not the headrest.
Mine has the more "squared off" base. Making it a few inches shorter than the "Rounder" base. I think it should have the more "Rounded" longer base.
Do you agree?
Tom
skou
Post by skou »
Tom, over 60+ years, the base may have been changed.
But, if my memory (why can I buy decent memory for a
few dollars, but not "my" memory) serves me, the E model was the
"round" base was an earlier adaption. The more "squared off" base was
a later feature. Skip (at the ER group) would know, for sure.
steve
10 ER, stripped down.
e2512 wrote:I didn't explain that very well.
Do you agree?
Tom
AIUI the 'squared' off base came later, so yes I agree.
rpd
Post by rpd »
I agree a 10E would have originally had the longer base.
I have two 10ERs, one has the longer rounded pivot base and the other has the squared off pivot base.
Below is a list of 10E/ER design changes compiled by Skip Campbell and posted on the Yahoo Shopsmith 10ER Users forum.
It shows the change to the shorter squared off pivot base didn't happen til1951
Skip Campbell
--- 10E and 10 ER Factory modification from owners manuals ---
The following data was mined from the 10E and 10ER owners manuals.
This may help you determine the age of your machine. Bare in mind
that all of these machines are near 60 year or older. There is
always the possibility that a lost or broken part has been replaced
and possibly with one from a later or earlier machine. Comparing
with other machines in the survey data may help determine if that
is the case.
Nov 8, 1947
Magna 10E Shopsmith introduced at Montgomery ward stores
nation wide and in their catalog.
4 bolt cast iron headrest changed to aluminum mid 48.
aluminum extension table bracket held by two studs w/wing nuts
wooden extension table top
flip out stop on table trunnion
no table elevation until optional accessory came out
Late 1948
10ER introduced with revised:
table trunnion with spring loaded detent lever
tailstock with table bracket groove
cast iron extension table bracket w/ aluminum ext. table
chrome quill spring housing and depth gauge
redesigned rip fence with rear lock
redesigned miter gauge w/detents and clamp mount hole
table raiser arm and crank
redesigned belt/pulley guard (flat top for more clearance)
1949
Jigsaw and other accessories added
no machine changes that I can tell.
Oct. 1950
Jan, 1951
vertical lock knob, from alum. knob to steel (101-12x to 101-10?)
tailstock lock knob, from alum knob to steel w/hex (pic chg, same #)
two bolt headrest cast iron
April 1951:
Solid saw guard
redesigned sanding disc
knurled hubs, quill pinion shaft
pivot base footprint change
raiser crank? part number change (103-40x to 103-39x)
tool rest arm, set screw moved inline with arm
vertical lock screw, part number change (101-12x to 101-10)
tailstock locking knob, part # chg. same pic (104-7RX to 104-9)
Feb 1952
One piece wedge locks
Long slot in ext. table bracket
Sept 1952
hollow table support tubes
Feb 1953
thin way tubes (Mark V style)
