84 yr. old Delta Scroll Saw
WmZiggy
Post by WmZiggy »
Since this winter I have been buying old tools from a women who has been liquidating her deceased husband's shop. When I first laid eyes on this Delta 24" Scroll Saw, I knew I had to have it. It had been in her husband's family since it was purchased new, and obviously cared for since it still has it's original decals and paint job, and no rust. And since I don't own a SS scroll saw, and the price was $100, I brought it home two weeks ago and finished my refurbishing job today.
The dear lady I bought this from had the original instruction booklet. At the bottom it's dated 12-31. Now there is a YouTube video for a 1936 model which is interesting to watch and was my first help in identifying what I had (when she first showed it to me she hadn't found the booklet).
https://www.youtube.com/watch?v=VmYxw4HpBeA
However, the table on his 700 model (mine isn't numbered anywhere) is smaller. The one I have is 16"x16" and steel. The one on YouTube looks to be aluminum and smaller. Thus I am guessing, since table sizes (except in SS's case) tend to get smaller rather than larger over time, and aluminum became the rage in the mid-1930s,that the saw I have was new around 1931. If anyone out there is familiar with this Delta scroll saw please let me know.
Here is a picture in the garage after I got it home.
IMG_20150601_072836_171 (Mobile).jpg (68.78 KiB) Viewed 8392 times
Now the stand is original to the saw too. It has it's decal on the side. There is also a really cool light that Delta may have sold with it. I can't tell. It's looks professionally made, perhaps off of some other machinery.
IMG_20150601_073226_253 (Mobile).jpg (67 KiB) Viewed 8392 times
The motor was made by Menomonee Electric Company in Michigan. I am guess again but I believe it's older than the saw, perhaps 1920s or earlier. If anyone knows, let me know. It's 1/4 hp with an odd ball 1750 rpm on the brass plate.
IMG_20150601_073647_246 (Mobile).jpg (55.26 KiB) Viewed 8392 times
It was loaded with dust and dirt so my first job was cracking it open and seeing what I had. An AF NCO who worked in the electric shop of my old Unit told me to just clean the magnet with Simple Green and wash it out, which I did. I then set it aside and let it air dry.
IMG_20150604_110515_864 (Mobile).jpg (74.55 KiB) Viewed 8392 times
While checking out the armature I found that one of the starting pads (there are 3) was missing a brass pin that held it up. Consequently one pad rode on the Commutator rather than lifting off with centrifugal force. I turned a new pin on the lathe and pressed it in. Cleaned the armature by spinning it on my lathe.
IMG_20150604_105425_556 (Mobile).jpg (62.01 KiB) Viewed 8392 times
IMG_20150604_105512_604 (Mobile).jpg (81.73 KiB) Viewed 8392 times
The motor has brass sleeve bearings with an oil cup and wick that sucks-up oil. The wick rides on the shaft.
IMG_20150604_112051_412 (Mobile).jpg (81.41 KiB) Viewed 8392 times
I buttoned it up and tested it out. I think it might be good for another 100 years. More to come in part 2.
Re: 84 yr. old Delta Scroll Saw
1750 rpm is not 'odd ball'. ;)
Excellent approach on restoring. Keep those wicks saturated!!!
WmZiggy
Post by WmZiggy »
JPG wrote:1750 rpm is not 'odd ball'. ;)
Most everything I have ever encountered is 1725. In fact in the booklet it calls for a 1725 rpm motor and a Delta pulley No. 5400, which I need to check out. Says that gives it the proper speed at the blade.
Tell me why 1750 isn't "odd"?
The 'rated' rpm depends upon different factors. Primarily the electric power frequency. A 'synchronous speed' would be 1800, 3600 . . . However an induction motor does not run at synchronous speed, but typically less. The amount less(slip) can be a result of the mechanical power delivered(more power == slower == more slip).
My guess is that more recent standards narrow down the hp/slip relationship compared to 'back then'.
Do not think a motor always runs at a specific speed.
WmZiggy
Post by WmZiggy »
Basically you are giving me Heisenberg's uncertainty principle, which seems to govern most of life. We mortals think we have a number, but it often "slips". Thanks JPG. I am glad the old beast runs, and I wasn't worried about 25 RPM one way or another.
