510/520 Compatible?
ibskot
510/520 Compatible?
Post by ibskot »
Anybody using a 510 Extension or floating table with a 520 set? I realize the fence absolutely would not work, however for support with tubes, would there be any hope of picking up a 510 table or two and using for outfeed? Lateral support? Anybody tried it?
Mike907
Re: 510/520 Compatible?
Post by Mike907 »
I'm not sure, but I don't think the 510/520 rails line up with each other, so they are probably not directly compatible for lateral support, but if you have the extension table brackets, I bet you could make them work for infeed/outfeed support, since the brackets are height adjustable.
http://www.shopsmith.com/ownersite/cata ... racket.htm
ibskot
Post by ibskot »
I do have them but never have used them. Interesting idea. I need to try them out.
