Peach Tree, Panel Clamps
ExtraMile
Post by ExtraMile »
I am loving these!
What is under all of this apparatus?
Another 3-D cross. This cross, will be donated to a new and budding church :)
Blessings.
Incidentally, I was able to get two clamps with hard maple shafts (off of a local craigslist ad) for only $30... score :eek:
panel clamps2.jpg (55.89 KiB) Viewed 3805 times
panel clamps3.jpg (52.1 KiB) Viewed 3805 times
panel clamps.jpg (26.48 KiB) Viewed 3805 times
I am a true blue Xylophiliac, who also is a Nemophiliac ;)
Bruce
Re: Peach Tree, Panel Clamps
Post by Bruce »
You got a good deal for sure. I hope you didn't use your MV table for assembly. I wouldn't enjoy cleaning up glue squeeze out. :(
Yes - Good Score - The cause was just!!!!
Are the cauls(shaft) curved slightly(fatter in the middle)?
ExtraMile
Post by ExtraMile »
Bruce wrote:You got a good deal for sure. I hope you didn't use your MV table for assembly. I wouldn't enjoy cleaning up glue squeeze out. :(
Yes, but I had a layer of wax paper directly under the glued surfaces.
ExtraMile
Post by ExtraMile »
JPG wrote:Are the cauls(shaft) curved slightly(fatter in the middle)?
Yes they have a very slight taper.
The horizontal bar of the cross isn't a full 48 inches, so I added a piece of scrap at both ends, so I could use the clamp :cool:
