Shopsmith not so pricey afterall
Ohgary
Post by Ohgary »
]This is some blade. But it will fit on a Mark V arbor! (1-1/4 inch)
Re: Shopsmith not so pricey afterall
Ohgary wrote:]This is some blade. But it will fit on a Mark V arbor! (1-1/4 inch)
Are you sure? With a quarter-inch kerf, the arbor nut might not go on all the way! And I'm pretty sure that it would require a special table insert. :D
If the price & kerf aren't typos, what do you suppose those blades are for? :confused: Or maybe that should be a 78" diameter blade?
If the price & kerf aren't typos, what do you suppose those blafes are for? :confused: Or maybe that should be a 78" diameter blade?
My guess is that this blade is for cast iron.
rogersk
Post by rogersk »
Good guess!
FEIN 63502099004 Saw Blade, Circular, 7-7/8 in.. More details: Saw Blade, Primary Saw Application Specialty, Tip Material Steel, Blade Type Circular, Blade Dia. 7-7/8 In., Number of Teeth 50, Arbor Hole 1-1/4 In., Kerf 0.250 In., Diamond Knockout No, Cutting Depth 1-3/4 In., Max. RPM 300, Application For Cast Iron Cutting, For Use With Mfr. No. 73601300619, 73601000403, 75602300009, 75602400005
