A couple of years ago, I went to Charlotte Michigan to take John Wilson's Shaker Oval Box class and really enjoyed the learning from John. Link to his web site: http://www.shakerovalbox.com/
Last year I bought John's book Making Wood Tools, so earlier this year, I decided to make the first project in his book, a block plane. The plans include all the information needed, plus how to make and heat treat the blade. Making the plane was relatively easy and it was a fun and useful project. The materials are Walnut and Birdseye Maple.
Brian
Mark V-500 Purchased New In 1980, SS Bandsaw (free), SS Jointer, SS 6x48 Belt Sander (free), SS Storage Station (free), Powermatic 64A Table Saw, Powermatic 1140F Drill Press, Delta 46-460 Midi-Lathe, Delta Scrollsaw, Bosch 12" Dual Compound Miter Saw, MLCS Router Table w/Bosch Router, Penn State dust collector.
Thanks guys! Here is a picture of my Shaker Oval Boxes. The material is Cherry.
Brian
Home designed and built CNC router, another CNC router desktop size, Avid 5x10 Pro CNC w/ATC, CNCed G0704 milling machine
Laser engraver
Way too much other stuff and not enough space
Dick 1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
Thanks rjent! All of the work on the block plane is mine, but I must give some credit to John Wilson for the boxes. The class at John's Home Shop consists of 3-hours on Friday evening and then all day on Saturday. John supplies all of the material and lunch on Saturday, all for $90. The bands for the boxes are supplied with the fingers already cut to shape. When taking the class, only some trimming with a Stanley knife is required to clean the finger edges at a slight angle. The Friday class time is used to trim the bands, soak them in 200° water, forming the bands to the cores and then clinching the copper tacks. The last step is to add the top and bottom shaper blocks and let the bands dry overnight. Saturday is spent in fitting the bottoms of the boxes and the tops of the lids and securing these with pegs (tooth picks). All that is required after the class is to sand and apply your choice of finish at home.
Brian
