Sticker Shock - Big Time
I am playing around with my recent modification to the Mark V. I decided, for reasons of convenience, that I wanted to have an extra Base Arm Pin (518378) available to me.It was hard to locate but I finally found it in the online catalog listed for $7.89.
When I tried to order on line, the system tried to do a part number change so I decided to call. I was fearful that they might be trying to send me a part for the double tilt. Well, this part might work as well for the double tilt but the pin Shopsmith is sending me is 522816 and it lists for $20.35.
Surprises like this will prevent me from buying new.
$8.00 plus shipping to be added onto that.
ERLover
Re: Sticker Shock - Big Time
I hear you and feel your pain, but it is the Mother Ship, and we need her!!! Dusty I can pick up a greenie here in WI for 200$+, with some SPTs, it is a bargain, to make it into a dedicated piece of wood working machinery and a variable speed besides.
Bet it has two grooves for c-clips rather than a hole for a tension pin.
3/4" cr barstock would work.
For that $ you can get a whole base casting on E-bay(sometimes)
ERLover
Oh JPG you are so good!!!! More pics of the tree at night this Autumn??!!!
ERLover wrote:Oh JPG you are so good!!!! More pics of the tree at night this Autumn??!!!
Forget the numbers on the wall, Autumn has not arrived here yet. Besides color does not show up at night, only snow does!
Oh Lord, I pray thee, help this man see the difference between leaves and snow!
ERLover
I think God only lets in snow in KY to punish the wicked/sinners!!!!LOL!!!
Chill 'Robert'.ERLover wrote:I think God only lets in snow in KY to punish the wicked/sinners!!!!LOL!!!
You are probably correct. What I fear is that Shopsmith may concentrate their support effort (and money) on the PowerPro and leave the rest of us to fend for ourselves.JPG wrote:Bet it has two grooves for c-clips rather than a hole for a tension pin.
3/4" cr barstock would work.![]()
For that $ you can get a whole base casting on E-bay(sometimes)!
I just cancelled my order with Shopsmith. BTW - they do not issue a confirmation # for cancellations but the online order status has ALREADY been changed.
I'll use a wooden dowel to do what I wanted the pin for. Thanks, you have made this frugal old man happy.
Sadly they have been concentrating on 'current' production for quite some time. I have attempted obtaining Mark 5/V parts that have been redesigned, and no go! Case it point, the stop pin od in the miter gauge has been reduced. The older, larger one is N/A. So if you have an older one, do not drop it and bend that pin!
Also, if a part is part of an assembly procured as a complete assembly, they may not have a part readily available.
Part of lean operating which has allowed them to continue. Be thankful for that!!!
ERLover
Chill 'Robert'.???? Its Michael Jpg
