Stand alone Bandsaw
Beave2012
Stand alone Bandsaw
Post by Beave2012 »
So a while back I picked up a shopsmith jointer with stand for $100. It has the mounting stand and SS power switch, and works fine for my jointer, however I could really use a Stand alone bandsaw instead of a stand alone jointer. The motor is 1/2 hp @ 1725 rpm. Do you think it would work as a bandsaw? How do I get the right pulley sizes?
-Beave
wa2crk
Re: Stand alone Bandsaw
Post by wa2crk »
Beave
A well stocked farm supply store (Tractor Supply Co) or others similar should stock a wide variety of pullies. You would have to do a little bit of math in order to get the right combination of pullies for the job. As an example, if you put a 3" pully on the bandsaw and a 2" pully on the motor the ratio is .666. So if the speed of the motor is 1725 RPM the bandsaw speed would be about .6 of 1725 or about 1035 RPM which equates to roughly 3100 feet per minute for the blade speed. Personally I think that 3100 FPM is a bit high for the bandsaw so I would pick a different ratio to slow the blade down a bit.
I think that the 1/2 HP and 1725 RPM motors is standard on the power stands except for the planer.
PS Look at page 22 of the online bandsaw manual for more info
Beave2012
Post by Beave2012 »
wa2crk wrote:Beave
Thanks for the info. Looks like 700 to 1050 rpm is recommended speed for the bandsaw. So a 4" on the bandsaw and a 2" on the motor would get me to 862.5 rpm on the bandsaw. Sound right?
-Beave
Beave2012 wrote:
wa2crk wrote:Beave
"Sounds" correct to me. :cool:
Beave2012
Post by Beave2012 »
Turns out the jointer uses a 4.5" pulley and a 2" pulley. I might be able to just swap the positions and bingo 766 rpm. Wow that's handy. Jointer and bandsaw have opposite pulley ratios.
-Beave
Beave2012 wrote:Turns out the jointer uses a 4.5" pulley and a 2" pulley. I might be able to just swap the positions and bingo 766 rpm. Wow that's handy. Jointer and bandsaw have opposite pulley ratios.
And the shaft sizes?
Beave2012 wrote:So a while back I picked up a shopsmith jointer with stand for $100. It has the mounting stand and SS power switch, and works fine for my jointer, however I could really use a Stand alone bandsaw instead of a stand alone jointer. The motor is 1/2 hp @ 1725 rpm. Do you think it would work as a bandsaw? How do I get the right pulley sizes?
The motor is fine. That is what I have on my SS stand alone Band Saw. I believe the motor pulleys are all the same (JPG or Dusty will correct this if I am wrong). You just need to get the correct pulley fore the Band saw from the MS.
Beave2012
Post by Beave2012 »
Both are 15mm
-Beave
Both are 15mm
Last I checked, the jointer shaft was 1/2" and the bandsaw shaft was 5/8".
Motor shaft?
Beave2012
Post by Beave2012 »
JPG wrote:
Beave2012 wrote:
Both are 15mm
Motor shaft?
I used a caliper and bandsaw shaft was 15mm, the motor shafts was 15mm.
I did find the mounting base manual and the pulley ratios. You do indeed just swap pulley positions from jointer for the low end bandsaw, same part numbers too. I could use a 3" instead of a 2" as well for a faster band saw speed.
I do need a 40" v belt though. Are belts standard between manufactures? I hate to pay shipping for a belt
-Beave
