Waxing the Shopsmith
gatheringsplinters
Post by gatheringsplinters »
Quick question for you guys.
When I first got my Shopsmith I waxed it as per the manual with SC Johnson Paste Wax (Original Formula). When I go to apply wax again do I need to use Mineral Spirits to remove the initial layer before applying it again or can I just put it over the old coat and buff it out?
Thanks
Mark V 500 (1984) - Shopsmith Bandsaw (Older Model with Cast Iron Table) - Shopsmith Jointer
Woodworker Level: Beginner
Boulder Colorado
Instagram: gathering_splinters
Youtube: gathering splinters
nuhobby
Re: Waxing the Shopsmith
Post by nuhobby »
I think there will be sufficient solvents in the new wax to effectively have you 'starting fresh' without any pre-preparations.
Enjoy!
Chris
rjent
Post by rjent »
Nick Engler talks about how the "new" layer of wax dissolves the "old" layer and therefore no "buildup" takes place. He said that on the video when he is working with the pro planer. I have always assumed that it applies to the way tubes as well.
JMHO
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
gatheringsplinters
Thanks guys! Good to know I should be able to just apply a new layer over the old!
Boulder Colorado
If you polish out the wax after it is applied, there is no build up! However, don'y put wax on top of wax without polishing out the forst coat. If that first coat is left to "dry", you may find yourself working hard to bring back the shine.
That is the condition I have now. A well waxed machine that was never polished out. It looks dull and will take some work to get it back to its original shine.
ERLover
Post by ERLover »
A damp rag of Mineral Spirits will bring it back without much work Dusty.
If there is so much wax 'left', why does it need it?
A facetious way of saying there is not likely much wax left anyway. ;)
Besides shine is not the objective - slick, rust proof is. :)
Polishing helps the slick at the expense of anti oxidation properties.
gatheringsplinters
JPG wrote:If there is so much wax 'left', why does it need it?
I'm trying to stick with the upkeep schedule listed in the manual. That's the only reason I've got to reapply the wax at this point.
Boulder Colorado
ERLover
Post by ERLover »
Some here and me on the raw steel and cast iron use an oil based paint thinner, I am going to miss spell it Penitrol?? then wax. I shellac my raw steel and cast iron too, then wax.
Here is the site. and info for raw metal and aluminum
http://www.flood.com/paint-additive-solutions
Ed in Tampa
Post by Ed in Tampa »
I am a believer in Flood Penetrol also.
Living hot humid Florida surrounded by salt water Penetrol and Johnson paste wax works!
