Shopsmith Bandsaw Bearings
In my on-going Shopsmith restoration, I'm still waiting on backorders: a couple of quadrant assys & a power cord. I am one double-bearing quill bearing short due to an Ebay seller listing one twice, when he only had one. So rather than pay to ship just one bearing, I took my band saw cover off & figured I'd get the bearing numbers so I can spread the shipping cost over several bearings. I'm a believer in replacing bearings rather than try to re-lubricate sealed bearings.
I took the wheels off. The upper wheel uses two needle bearing assemblies marked USA B INA SCE88. These are common.
The lower wheel has what looks to be an idler assy shaft. The markings are: 885144 A Japan OPC. I Googled it and found this is a common water pump assembly part.
The tensioner has two 627Z bearings which are one next to the other. These are common bearings, I believe.
The upper & lower guide bearings are marked SST WC77037-1. I was unable to find these on the net. I understand in the old bandsaws, these bearings were made of bronze. Anyone know of these?
Tony
Tony
paulmcohen
There is another thread started by LDH, he posted a great set of plans to do an upgrade to the bearings. I have attached it again here. I have done it and it works great, I have lots of exta parts because I purchased items in bulk, PM me if you are interested.
[ATTACH]1504[/ATTACH]
UpperLowerBackup.PDF- (34.07 KiB) Downloaded 2843 times
Paul Cohen
Beaverton, OR
Beaverton, OR
The upper bandsaw wheel will accept GB88 bearing also. The upper and lower bearing guides will accept 77037 or WC87037 bearings. I get them from http://www.ebatmus.com for customers. The old bronze bearings just needed lubication when oiling the headstock. I remove the bronze bearings and use a good grade of wheel bearing grease. Never had any problems with my bandsaw in 28 years. I will continue to use the bronze bearings in my personal bandsaws.
backhertz wrote:In my on-going Shopsmith restoration, I'm still waiting on backorders: a couple of quadrant assys & a power cord. I am one double-bearing quill bearing short due to an Ebay seller listing one twice, when he only had one. So rather than pay to ship just one bearing, I took my band saw cover off & figured I'd get the bearing numbers so I can spread the shipping cost over several bearings. I'm a believer in replacing bearings rather than try to re-lubricate sealed bearings.
Tony
eagleflight53
- Bronze Member
bandsaw bearings
I could use a little help finding the bearings for my bandsaw; particularly the upper wheel needle bearings. I appreciate the help from this site.
Your answer is in post #3.
I have been using 2 higher quality 627Z bearings at all 3 bandsaw bearing/bushing locations for customers. I had to use a very thin shim on the inside bearing on the upper and lower blade guide locations and file a small notch on the blade guides for the outside bearings to clear. I used the 514008 shoulder screw in all 3 locations. I will continue to use the bronze bushings on my personal bandsaws and lube them when I do the headstock.
I have ceramic guide blocks available for the Shopsmith bandsaw.
Blade guide assembly
On the shopsmith bandsaw, is the blade guide that holds the bearings a die cast or machined part?
Problem is that this is a bearing/shaft assembly where the shaft is part of the bearing and Shopsmith appears to have molded the wheel on the shaft making it impossible to change just the bearing/shaft.backhertz wrote:The lower wheel has what looks to be an idler assy shaft. The markings are: 885144 A Japan OPC. I Googled it and found this is a common water pump assembly part.
Or did someone find a way to remove the shaft from the wheel or bearings?
Brian
briancs wrote:Problem is that this is a bearing/shaft assembly where the shaft is part of the bearing and Shopsmith appears to have molded the wheel on the shaft making it impossible to change just the bearing/shaft.
Brian
I think Nick once posted that he tried to remove this water-pump-type bearing with a 100 ton press, and it wouldn't budge....
Chris
- goodolesmitty
- Bronze Member
Brian
I'm happy,happy,happy!
Today I put a 3 arm puller on my '59 Magna (Shopsmith) lower band saw wheel, and it easily
I thought I was doomed to start saving up for the $100 complete assembly.
Especially after I read:
"I think Nick once posted that he tried to remove this water-pump-type >bearing with a 100 ton press, and it wouldn't budge...." ~Chris
Maybe Nick was trying it on a different year band saw?
...and Bill, I appreciate your insight on keeping the bronze bushed guide bearings. Will save me some money!
John ~S.F. Bay area
10ER #39030 (+ 3 more), Mark V 1980, 10ER Jointer, A-34 Jigsaw I'm testing, 10ER SPT mount for Bandsaw, Belt sander, Scroll Saw
