v belt adjustments
aldeteresa
v belt adjustments
Post by aldeteresa »
Thank the lord found out about you. i need a miracle does any body have the adjustment procedure for an er 10 variable speed changer. the shopsmith manual only shows it but the adj is foe single belt
georgek1
Post by georgek1 »
If you will go to this site, http://groups.yahoo.com/group/Shopsmith10ERusers/ you can find all of the documents you need for the 10er. Good Luck, it is a good machine.
George
Ormond Beach FL SS 520, Jointer, Band Saw, Miter Saw, Radial Arm Saw, OPR, Router Table, 5 Routers, Incra 5000, Table top Drill Press, Thickness Planer
