Anyone near DC have a set of double bar clamps?
I have a project for which I would like to use a set of the Shopsmith double bar clamps (either the 24" or the 36" size would fit my project). Went to order some from Shopsmith and they are back ordered with no delivery date.
If there is anyone near DC with a set that I could borrow for a project, please send me a PM.
Thanks,
Al
Thanks,
Al
- Jack Wilson
Re: Anyone near DC have a set of double bar clamps?
Al,
Not sure what you are doing; but can't you use a clamping caul.
Also, Woodcraft sells a version of them.
Jack
Jack
SS Mark 7 PowerPro, 2 SS Bandsaws, SS Belt Sander, SS Jigsaw, 13" Steel City Lunch Box Planer, SS Jointer, Jet 22-44 Drum Sander
Yup, those are plans B & C!Jack Wilson wrote:Al,
Jack
davebodner
If I had them, I'd certainly lend them out.
I might also be able to lend a hand at your boat's first wetting. I think we all feel we have a stake in that.
Well, that didn't take long! They arrived from Shopsmith on Wednesday. At some point, I will try to do a review.
- BuckeyeDennis
You'll like them a lot. It's a bit of a pain to get the bar clamps situated around the glue-up, but that gets easier with practice. One past that, they work like a charm.algale wrote:Well, that didn't take long! They arrived from Shopsmith on Wednesday. At some point, I will try to do a review.
At first I used wax paper to keep the glue off the pretty cauls. A PITA, that is. I later read some excellent advice to apply packing tape to them prior to glue-up. Much better. Just peel off and discard when done.
Also, the "minimum width" spec for a given clamp capacity is really a non-issue. I have three of the 36" clamps, which are supposedly only good for panels of 16" or greater width. Not true. If I need 12" panels, for example, I simply glue up two or three narrow panels at the same time. Or if I need only one narrow panel, I insert some spacer material alongside the glue-up. Then the clamps and I are all happy.
Thanks, Dennis. Mine came with a set of instructions on how to assemble them and use them both as double bar clamps and also how to use them as single bar clamps. The single bar clamp instruction (really just a sentence saying it could be done) was accompanied by a completely indecipherable (to me) sketch of what looked like a desk practically covered with single bar clamps going in every direction and I couldn't tell how (or if) they were fastened to each other. Ever tried to use them that way?
- BuckeyeDennis
I bought mine used, and didn't get any instructions with them. That's the first I've heard of using them as single-bar clamps.
If you have a nice flat workbench, I suppose that you could use single bars like ordinary cauls, but that wouldn't do anything to draw the glue joint up tight. If you post that sketch, I'll see if I can make sense of it.
I have sent a message to admin to see if there is an objection to posting the instructions.
I was not able to decipher that single bar clamp drawing, either.
