Re purposing taken too far
Is it Friday yet?
**********Warning you might not want to see this************
OK now I'm a big fan of re purposing things but some people just take things to far.
This is what I'm talking about:
i don't believe this.jpg (95.43 KiB) Viewed 2354 times
My brother sent me this, not sure where he got it but it is what it is
roy_okc
Re: Re purposing taken too far
Post by roy_okc »
Ah, yes. Those boards under that nifty ice chest/grill all-in-one have definitely outlived their usefulness. The all-in-one deserves a place on a much nicer parking spot.
Roy
Laser engraver
skou
Post by skou »
I certainly hope he left the flapper valve in,
or, as the heat melts the ice, the water will
put out the fire.
If it gets TOO hot, the heat will melt the flapper.
Same result.
steve
10 ER, stripped down.
skou wrote:I certainly hope he left the flapper valve in,
put out the fire.
Same result.
steve
That's the dousing the coals feature.
ERLover
Post by ERLover »
LMAO!!!!
greasemonkey2275
Post by greasemonkey2275 »
I think we are all looking at the wrong thing! What are the using the bottle of Jack Daniels for??? :)
Jake
Spokane, WA
greasemonkey2275 wrote:I think we are all looking at the wrong thing! What are the using the bottle of Jack Daniels for??? :)
Charcoal starter?
greasemonkey2275
Charcoal starter?
Right on; you can't trust those plastic starter fluid bottles!
Jake
Spokane, WA
Somebody explain to me the ground fire and the suspended ice cubes.
It appears the normal inlet hole is being used as a drain.
I wonder how many uses it takes to break the porcelain.
They fire porcelain don't they?
