Tomsalwasser Asked For It
db5
Post by db5 »
I've reformatted some how-to posts from this site, downloaded some things from Shopsmith and other websites and formatted and converted them to pdf files to print and put in an easy reference binder. (Most but not all are Shopsmith stuff). This is an alphabetical list. Many are 1-2 pages but some are quite long.
Having observed that many of you are greedy for more information I can post them here but don't know where they should go nor if how many can be posted at once.
Shop Tips PDF Files
45 Degree Jig
Align the Rip Fence
Band Saw Adjustment
Band Saw Fence
Box Joint Jig
Concrete Anchor for Jacobs Chuck
Cutting Circles with a Table Saw
Cyclone Dust Collector DIY
Dado Blade Template
Dial Indicator for Shopsmith (DIY easy and cheap to make)
Disc Sanding
Dovetail Jig
Feather Boards
Floating Table
Hand Scrapers
Hexagon Chisel
High Speed Adjustment
How to Reset the Speed Control Dial
Inches to Decimal Conversion Chart
Installing a Link Belt
Lubricating the Shopsmith
Main Table Alignment Jig
Peg Board 1
Peg Board 2
Replacing the Speed Changer
Router Edge Guide
Router Table Insert
Saw Sharpening (hand)
Sharpening Drill Bits
Shopsmith 510 Extra Table & Carriage (exploded view)
Shopsmith 510 Saw Guards (exploded view)
Shopsmith 510 Work Table (exploded view)
Shopsmith Common Problems
Shopsmith Date of Mfg. (chart)
Shopsmith Headstock Rebuilding Checklist
Shopsmith Mark VII Motor Test
Shopsmith Setscrews (chart)
Squaring a Fence to a Blade
Shopsmith Miter Gauge (exploded view)
