Saw Blades 5/8" vs 1-1/4" arbor?
shydragon
Post by shydragon »
When I was going through a box of shopsmith stuff, I found (4) blades with 1-1/4" arbor. (2) with carbide teeth and one of those being a Forest II thin kerf. And (2) with non-carbide. Apparently, I bought extra arbors for these, because I found (3) of those.
Then I found (5-6) 5/8" arbor 10" blades, two of them being brand new. Must have used them on the radial arm saw I had.
I see that you can buy a 5/8" saw blade arbor from SS. Are any of you, using 5/8" arbor blades of your SS?
Since, one of the blades is a Forest II with 1-1/4" arbor, I did a search for blades with the 1-1/4" arbor and found nothing, except for 12" blades. Where the heck does SS get theirs?
Pat
Oregon
1992 SS 510, 11" Bandsaw on power station, 4" jointer, Pro Planer, Incra Miter 2000, Incra Ultimate Fence Router Pkg, Grizzly 6" Parallelogram Jointer.
paulmcohen
Post by paulmcohen »
I assume Shopsmith gets them from the blade manufacture in volume with the hole size they want. Several quality blade makers will provide their blades with 1 1/4" hole on special request, Forrest charges $9 extra for a 1 1/4" hole.
I have all 1 1/4" holes on my blades except the dado (almost) all directly from Shopsmith.
Paul Cohen
Beaverton, OR
Shopsmith sells a 5/8" arbor. With a new Forrest blade in hand, the arbor would be a good purchase.
Or you can ship the blade to me. I already have an arbor.
I use both 5/8" and 1 1/4" and really don't see a difference in performance.
http://www.forrestblades.com
Bruce
Post by Bruce »
Forrest will bore the 1 1/4" arbor hole for a fee when you order a blade.
kd6vpe
Post by kd6vpe »
I have and use both types of arbors. I too see no difference in the way they work. I have the 1 1/4" arbor on my rip blade the the 5/8" on my plywood and crosscut blades. No real reason other that those were the blades I had and their sizes. I'm not sure yet what sizes I will buy next as I'm still trying to figure out what blades I need. Nick's sawdust session really help me understand more about blades.
SS 500 upgraded to 510; SS bandsaw; SS jointer
SS Oscillating Drum Sander; Universal Lathe Rest;
lathe duplicatior, shaper fence and shapers; SS Belt
Sander
Jim
www.youtube.com/kd6vpe
shydragon
Post by shydragon »
The Forest blade, I have is 1-1/4" arbor. I just had 5 or 6 blades with 5/8" arbor, two of those being new. I was just wondering if there was any problem using them on the SS. From two of the replies, it seems that won't be a problem, so I'll order a 5/8" arbor from SS.
Thanks for everyones help.
Pat
Oregon
I would suggest that an arbor for each blade you intend to use is wise.
hardway
Post by hardway »
In yesterdays Sawdust Session, I am fairly sure that Nick said that SS saw blades were made by Frued. I am not sure when in the presentation but it could have been when he talked about kerf width in making the splitter on the outfeed table.
Tom
Masontown, WV
I thought the manufacturer of Shopsmith blades changed to Amana. They used to be Freud.
solicitr
Post by solicitr »
I use a 5/8" because all my existing blades are (and the 1-1/4's that came with my used SS were steel, not carbide). No problems at all. The Infinity Combo-max, in particular, cuts like buttah.
Bill
Richmond, Virginia
