Frankenmotor?
- retiredsoldier919
Frankenmotor?
I saw this Emerson motor and wondered if it would be possible to take the shaft and rotor from the Shopsmith Emerson 1 1/8 hp motor and put it into this unit. The though being that you take what is special about the Shopsmith version and make it work in a different motor. Has anyone done this? I know mounting it would require additional work, but doesn't seem impossible.
http://www.spapumpsandmore.com/Softub_M ... m-6497.htm
Last edited by retiredsoldier919 on Sun May 01, 2016 7:36 pm, edited 1 time in total.
Re: Frankenmotor?
In a word NO. Many things come into play. Type of motor, motor speed, shaft size, bearing diameter, rotor construction, number of windings, winding wire size, case design and mounting method and on and on.retiredsoldier919 wrote:I saw this Emerson motor and wondered if it would be possible to take the shaft and rotor from the Shopsmith Emerson 1 1/8 hp motor and put it into this unit. The though being that you take what is special about the Shopsmith version and make it work in a different motor. Has anyone done this?
Re: Frankenmotor?
Question is, WHY?
No not worth the effort(which is a total unknown).
- retiredsoldier919
Re: Frankenmotor?
I figure as a way to get around Shopsmith's not so great choice of motor. Or maybe getting a more available motor. Not necessarily this one, but any closely designed motor. There should be an alternative to putting down the $ for a Power Pro upgrade.JPG wrote:Question is, WHY?
Re: Frankenmotor?
I am not sure what that means. I have a 60 year old 10ER with the original motor. I have a 30+ year old that I bought new that has a perfectly good motor. I have 3 more 10ER's and a MK V with perfectly good motors.retiredsoldier919 wrote:I figure as a way to get around Shopsmith's not so great choice of motor. Or maybe getting a more available motor. Not necessarily this one, but any closely designed motor. There should be an alternative to putting down the $ for a Power Pro upgrade.JPG wrote:Question is, WHY?
So why is the SS motor not so great a choice? You don't have to buy a Power Pro just buy a replacement motor for the one you have.
Re: Frankenmotor?
Please Explain!
ERLover
Re: Frankenmotor?
I totally agree with John B, I have 3 ERs with the original motors, a 57ish greenie, and a 80 something grayling, all original motors. My nephew has a 54 has a 54 greenie and a Er same thing, original motors and for all of them have not done any work on the motors. Changes some cords and switches thats it other then a bit of blow the dust out.
- retiredsoldier919
Re: Frankenmotor?
I am referring to the Emerson 1 1/8 hp motor specifically. I've read on this forum and spoken to others that state that this is a poor quality motor in comparison to past versions. I myself have a 10er that is running great with very little tlc. I wish I could put it in my Mark V.JPG wrote:retiredsoldier919 wrote:I figure as a way to get around Shopsmith's not so great choice of motor. Or maybe getting a more available motor. Not necessarily this one, but any closely designed motor. There should be an alternative to putting down the $ for a Power Pro upgrade.JPG wrote:Question is, WHY?
Please Explain!
Re: Frankenmotor?
ANY motor built today will fail a durability test with 60 year old motor designs. They will likely win a weight/cost/efficiency test.retiredsoldier919 wrote:I am referring to the Emerson 1 1/8 hp motor specifically. I've read on this forum and spoken to others that state that this is a poor quality motor in comparison to past versions. I myself have a 10er that is running great with very little tlc. I wish I could put it in my Mark V.JPG wrote:retiredsoldier919 wrote:
Please Explain!
So the crappy part has nothing to do with the 'brand'. More so the times.
Re: Frankenmotor?
Maybe, if I read more of your postings, I would not have to ask this question. What is wrong with the Emerson motor that you already have?retiredsoldier919 wrote:I saw this Emerson motor and wondered if it would be possible to take the shaft and rotor from the Shopsmith Emerson 1 1/8 hp motor and put it into this unit. The though being that you take what is special about the Shopsmith version and make it work in a different motor. Has anyone done this? I know mounting it would require additional work, but doesn't seem impossible.
Then the real question, yours. Can you reconfigure the new motor to make it compatible with your Mark V. Probably not but because the Emerson in the Mark V is a special build for Shopsmith. Emerson will not even talk to you about motor specifications on that motor, let alone sell parts to you to repair it.
That said, I am not certain that you could not mix parts from other Emerson Mark V motors to create one good one.
