Will it work?
lilgodwin
Will it work?
Post by lilgodwin »
Will this work on the Mark V?
It looks like it uses the standard spindle. So would it be as simple as removing the pulley and attaching an accessory knob?
Re: Will it work?
Yep and Yep!
Shaft should also protrude from the back side. Can be mounted/used on either end of the SS.
lilgodwin
Re: Will it work?
Post by lilgodwin »
Sweet, thanks! Been looking for a good deal on one of these. We'll see how this goes.
everettdavis
Re: Will it work?
Post by everettdavis »
As JPG said, Yes....
What you see is one set up for a standalone tool with a motor beneath.
Everett
beltsander on stand.jpg (35.04 KiB) Viewed 4302 times
