Rip Fence not square
Mole
Post by Mole »
I have a Mk5 and find that when I tighten the knob of the rip fence, the far end pulls in by about 2mm so the fence is not square to the worktop/saw bench.
I have tried adjusting the set screw to no avail.
Any suggestions would be appreciated.
Re: Rip Fence not square
Mole wrote:I have a Mk5 and find that when I tighten the knob of the rip fence, the far end pulls in by about 2mm so the fence is not square to the worktop/saw bench.
The set screw should not be used for that purpose. For all practical purposes the set screw could be removed. Do you have a manual for the Mark 5? The fence alignment procedure is there.
If you have a 500, the alignment procedure is available on line.
Look here for what is available. http://www.shopsmith.com/ownersite/productmanuals.htm
If a later model, say so and I'll attempt to locate what you need.
Doug Reid has done a large number of video presentations that are available on utube. I believe this one covers the fence.
https://www.youtube.com/watch?v=q6SpZg2sU6M
https://www.youtube.com/watch?v=0UvG0JGC2sw
If not, browse the facebook listings for more. As I said, there are many - all worth viewing.
wa2crk
Post by wa2crk »
HI
The reason for the fence moving is that the knob on the fence actually pulls the fence into square. If you try to use the fence set screw to align it you may damage the rails on the front of a 510 model. The set screw should be removed and then align the fence to the miter gauge slot. My fence does the same thing.
wa2crk wrote:HI
This is oh so true but only if the fence has been properly aligned to start with.
everettdavis
Post by everettdavis »
My understanding is the set screw is to bias the rip fence from being square, opposed to squaring it.
The rip fence can be offset to sand boards to a specific width. (Source http://www.shopsmith.com/academy/discsand/)
Some may refer to that as jointing the edge with a disc sander. The point of the setscrew was to introduce a bias into the normally squared fence to allow only one contact point.
Subsequently Shopsmith introduced the Conical Sanding Disc, providing that bias in the disc, negating the need to offset the fence.
Indeed some of the smoothest sanded edges I can produce come from the Conical Sanding Disc (which is also a component in the Jointer and Planer blade sharpening kit.)
Everett
Assuming this is a Mark 5 or a mark V-500 rip fence, the square adjustment(parallel to blade/miter gauge slot) is attained by loosening the two cap screws that secure the fence rail to the base, then retightening them.
BTW Dusty, when did Doug Reid change his name and persona? :rolleyes:
JPG wrote:Assuming this is a Mark 5 or a mark V-500 rip fence, the square adjustment(parallel to blade/miter gauge slot) is attained by loosening the two cap screws that secure the fence rail to the base, then retightening them.
I'm sorry but I do not follow you regarding Doug Reid.
everettdavis
I think that he is referring to Doug being mentioned as the author of a YouTube video, but the link is to a person who is not Doug.
Possibly a link error in the post creation.
Everett
everettdavis wrote:I think that he is referring to Doug being mentioned as the author of a YouTube video, but the link is to a person who is not Doug.
Everett
In many ways fer sure! ;)
Everett
Yup, an error in posting. I somehow cut and pasted the wrong link. However, even the one I intended to post (which has been added to my original post) does not get into fence alignment. I screwed up all the way around on this one.
I don 't give up easily though. Here, I'll take another shot at being of some assistance. One or the other of these manuals is likely to have answers to your question.
http://www.shopsmith.com/getting_starte ... Manual.pdf
re: page 19
re: page SM18
