Spiral scroll saw blades?
Between Do-It Best, Home Depot, Lowe's, and Harbor Freight, and Walmart, I found a disappointingly limited variety of scroll saw blades. None of which included the spiral ones. Is there a store (physical location... Not online) that you get yours from? Or can I really only order them online?
- BuckeyeDennis
Re: Spiral scroll saw blades?
Do you have a Woodcraft store nearby?
When I have to, I get mine from Woodcraft, otherwise I order from Flying Dutchman.
Paul B
If you have a Hobby Lobby, hobby store or model shop nearby they might. The HobbyLobby here has some spiral cut blades but are $9 a package and selection was limited to 3 sizes. If you have an immediate need those stores might be a chance to get something, though maybe not exactly what you want.
My closest Woodcraft is the same one as moggymatt but I have to drive 300+ miles to get there
so everything like that, I order on line and wait......
Good Luck
Be well,
Ben
Good Luck
Be well,
Ben
Great suggestions! Obviously two I should have thought of. I went with the stores I frequently visit and those didn't even cross my mind. I'll try hobby lobby first. Should be cheaper there.
Well, Hobby Lobby was a bust. Surprisingly the prices at Woodcraft weren't too bad.
I figured I'd have more local emergency options for that blade.
IIRC, I bought some at Rockler. If you need more for the future,,as moggymat said, go with Flying Dutchman. Better pricing and better quality.
ylilgodwin wrote:Well, Hobby Lobby was a bust. Surprisingly the prices at Woodcraft weren't too bad.
I think if you are looking for a local emergency option you are just not keeping enough blades on hand.
Usually order Flying Dutchman.
Second the flying Dutchman option. I have a small tub for blades and simply keep a ton on hand as some projects I have had has run through as many as 2 dozen blades (granted it was like 28 hours of actual run time).
Yet I shutter at the spiral blade need. I despise spirals as they break nearly 10x faster than straight blades. But, they do have their uses when necessary. I just can't believe how some people use them for ALL operations, I have yet to see a clean cutting spiral as compared to a nice straight blade.
-Beave
- rlkeeney
One you get it the sizes you use figured out buy those sizes the gross.
