New To Me Pro Planer
Steamdragon
Picked up a Pro Planer today for $200. I think it was a good deal and the guy who sold it to me took quite a bit of time showing me all of the ins and outs. He suggested new knives any recommendations?
Re: New To Me Pro Planer
Blade sharpening.
New blades from the MS(sit down to prevent sticker shock).
I hope they are wide enough to sharpen.
What size motor(HP) came with it?
Steamdragon
I believe it is a 1 3/4 motor. I was thinking the sharpening kit was a good plan but was wondering what git should I use?
Good you got the upgraded version.
Do you have a conical disk?
If so, either also get the sharpening jig or make one.
http://www.shopsmith.com/ownersite/cata ... rpener.htm
ERLover
If in fact a True Power Pro for $200 think yourself a Fathers Day Gifted!!! Is it a free standing or a SS driven model? For 200$ even if you buy a set of blades fro the MS you are lucky. I dont have one but there are other options out there for blades if they are the right size and configuration.
Steamdragon
It is the free standing unit.
ERLover
If it works, your a a thief, or being in CA he needed some drug money?Steamdragon wrote:It is the free standing unit.
I don't see the sticker shock here! You got the ProPlaner for a good price and the investment into the sharpening jig and new blades makes it a complete deal.
http://www.shopsmith.com/ownersite/cata ... knives.htm
Discard the blades that you received with the ProPlaner if they are less than 11/16" wide.
Some useful references:
http://www.shopsmith.com/service/pro_planer/index.htm
It was asked if this was a stand alone or a Mark V mounted ProPlaner.
A ProPlaner is a stand alone the other is referred to as a Mark-Mounted Planer.
http://www.shopsmith.com/ownersite/catalog/planers.htm
Is there a ProPlaner with other than a 1 3/4hp motor. If so, how old is it and is it part number 555082?JPG wrote:Good you got the upgraded version.
Did you know that a Mark-Mounted Thickness Planer can be converted to a "stand alone" by utilizing a Planer Power Stand 505977. However, the Power Stands are not currently available from Shopsmith. Wonder why! There is nothing really unique about the parts used to make a power stand.
Initially yes. 1 1/2 hp IIRC. It also has different pulleys. Cutter speed was increased with the later version. Since he has a 1 3/4 hp motor, he has the stand mounted version and the newer pulleys.dusty wrote:Is there a ProPlaner with other than a 1 3/4hp motor. If so, how old is it and is it part number 555082?JPG wrote:Good you got the upgraded version.
The sticker shock is that new blades will cost half as much as he got the planer for. Yes, still a steal!
If you did not get the blade height setting gauge, do get one.
