Jointer Manual Disassemble Maintenance?
suntower
Post by suntower »
1. Is there a manual for the jointer which I inherited along with this 'Greenie'?
2. Is there any maintenance other than waxing? It looks like just sealed bearings, but is there anything to be lubed?
3. The blade seems sharp enough, but it's pretty rusty. Should I disassemble to really de-rust?
As always,
---JC
IMG_1218 (Small).JPG (56.08 KiB) Viewed 9275 times
Greenie #317956. Jointer Model 620 #40077
everettdavis
Re: Jointer Manual Disassemble Maintenance?
Post by everettdavis »
Shopsmith sells 556076 - Jointer Manual for about $10
Search the forums for Jointer alignment and lubrication.
If you don't find what you are looking for try searching Google for Jointer and select entries it presents from http://www.shopsmith.com/ss_forum/ by restricting your search to the forum by using the following text in Google search:
jointer site:shopsmith.com/ss_forum
Here's one that came up you might find interesting
http://www.shopsmith.com/ss_forum/viewt ... 744#p68744
Everett
ERLover
Post by ERLover »
No on line Manuals from the MS on jointers, if it turns the bearings are fine.
Tables a bit of clean up and fence if need be, 220 wet then Shellac or Pentrol them, blades, only you know by running s0me hard wood and see how they cut
r.search.yahoo.com/_ylt=A0LEV7tqDYdX1BUAGGInnIlQ;_ylu=X3oDMTE0Z3I5OTQxBGNvbG8DYmYxBHBvcwMzBHZ0aWQDRkZVSTJDMV8xBHNlYwNzcg--/RV=2/RE=1468497386/RO=10/RU=http%3a%2f%2fwww.floodaustralia.net%2fproducts%2fpaint_additives%2fpenetrol.php/RK=0/RS=J9FkdSUtjoBcVif7yqiVLoI8oio-
ERLover
Post by ERLover »
Blade holder/drum only locks rusty, do some planing/edge jounting and report back in
suntower
Post by suntower »
Will do. I'm running through the Alignment video first (with Susan! :D ) Will try to actually -do- something for the first time with the gizmo this weekend.
Sorry. Can't help meself.
everettdavis
Look at adding the safety guard and fence extension with featherboards
Cheaper than any ER visit I've ever heard of.
Two safety upgrades worth the money. Check them out.
Everett
lyall
Post by lyall »
That is an even rarer manual for a 4E. A few differences, but functionally essentially the same as the later one.
ERLover
Post by ERLover »
everettdavis wrote:Look at adding the safety guard and fence extension with featherboards
Everett
I found a jointer to be typically a safe machine, routers and table saws seem to be the worst. But anything can happen, I always keep both eyes on my hands, and the distant/ prolifical?? vision on the cutting/work piece.
rpd
Post by rpd »
ERLover wrote:I found a jointer to be typically a safe machine, routers and table saws seem to be the worst. But anything can happen, I always keep both eyes on my hands, and the distant/ prolifical?? vision on the cutting/work piece.
Peripheral. ;)
