Belt sander frustrations
ChrisNeilan
Post by ChrisNeilan »
I purchased my belt sander about four years ago (maybe more) from a seller on Ebay. Happy purchase, I think from a member here. Came really clean with a new belt. Yesterday was the first time I tried to use it! Worked great for about two or three minutes, tracked well. Then the belt just came apart at the seam!- The adhesive holding it probably dried up and just let go. No problem, I had a brand new spare. A ceramic belt, Shopsmith branded, that I bought at Lowes. Can't get it to track, and it won't hold tension. What's the proper procedure to tension the belt? I turn the tensioning wheel but it won't hold. Anyone have a spare manual? I will probably order one, but a digital copy would be great!
Chris Neilan
ERLover
Re: Belt sander frustrations
Post by ERLover »
CN that tension knob is a real funky knob, I had the same problem, JPG sent me the instructions, printed them out and hang it by the BS, unfortunately, they are 93 miles away, I am sure he will chime in soon.
ChrisNeilan
Funky is right! At least the roller spins freely so I know it was lubed well. I watched the sawdust video last night and would hate to have to do that lube job! Someday I probably will, but not today. :) Is the tension spring loaded? If so, there is no tension on it now...
ERLover
Post by ERLover »
ChrisNeilan wrote:Funky is right! At least the roller spins freely so I know it was lubed well. I watched the sawdust video last night and would hate to have to do that lube job! Someday I probably will, but not today. :) Is the tension spring loaded? If so, there is no tension on it now...
CN, i haved not used mine for awhile and mine is loaded, but it is one of SS most illogical things to figure out on your own without the instructions, which I did not have either, until JPG told me how it works. Lets hope he is loosing at the Casino and comes home early :D
ChrisNeilan
Yes, but something tells me he doesn't lose much!
ChrisNeilan wrote:Yes, but something tells me he doesn't lose much!
I can assure you I try NOT to!
And never use an ATM!!!!
Never take more than I am willing to lose.
I usually take more home than I left home with.(some days the karma is just not cooperative :( )
FWIW belts that come with used sanders(strip sander as well) rarely last long.
Back to de problem at hand.
belt sander tension adj.jpg (73.63 KiB) Viewed 2470 times
And it has been a few months since a casino has seen me. Only Blackjack!!!!! Slot machines are a money pit.
ChrisNeilan
Thank you kind sir, I hope this works!
ChrisNeilan
Begorra! It worked!
Thanks JPG! I owe you a pint if you're ever in Connecticut! :)
ChrisNeilan wrote:Begorra! It worked!
Chris, do you mean to say that you had not read the instructions before. :eek:
ChrisNeilan
If I had instructions I might have read them! No information came from the eBay seller, at least none that I know of! This was the first Shopsmith accessory I had ever purchased, and the last one I have tried! Don't know what took me so long... It is a really good addition to the Shopsmith collection. I plan on ordering the manual soon.
