CFM of DC3300
CFM of DC3300
I have moved to the mountains of NC and working on a shop. The DC3300 says it has a 330CFM rating but I can not find the external static pressure the fan will handle. In other words 330CFM @ ?ESP. If the fan delivers 330CFM at 1"ESP then I would be very restricted on building a semi-permanent system but if will deliver 330CFM at 5" my options are greatly increased. I will call SS tomorrow and see what they say. Also is the extended hood worthwhile?
Re: CFM of DC3300
I don't know the answer to your first question about static pressure. I do think the 330 CFM is optimistic.
As to your second question, if you are using it in your house, get the 42 inch hood. Orherwise you are just moving the dust around your shop.
Re: CFM of DC3300
So the 42" hood does an effective job in filtering the shop air. That is good to hear, as i get older dust seems to bother me more.
Re: CFM of DC3300
I second the 42" hood.
How does sp = 4.6 to 7 in h20 sound?
This should help.
http://www.shopsmithacademy.com/SS_Arch ... ection.htm
This should help.
Re: CFM of DC3300
4.7" to 7" sounds great. That is a wide spread, I wonder why? I will call SS Monday and let everyone what they say.
Re: CFM of DC3300
The DC has three ports.Boots wrote:4.7" to 7" sounds great. That is a wide spread, I wonder why? I will call SS Monday and let everyone what they say.
7" = single port.
4.6" = all three ports.
330 CFM is with all three ports.IIUC
Single port is less CFM.IIUC
Do watch the video.
Re: CFM of DC3300
Thanks to everyone. SS emailed and called today and they said 5 to 7" which is the same as in the video JPG sent. Thanks again and I am glad to get the input of the 42" hood.
