Pro Plainer limits
moggymatt
Pro Plainer limits
Post by moggymatt »
Well..., I guess you can only put so much rustic hickory through the machine befor you have to sharpen the blades. (And it ain't much!)
Wife won't be happy I didn't finish that cabinet this weekend. :(
Paul B
Re: Pro Plainer limits
moggymatt wrote:Well..., I guess you can only put so much rustic hickory through the machine befor you have to sharpen the blades. (And it ain't much!)
Please explain why this is a Pro Planer issue. What is "Rustic Hickory"? Dirty reclaimed wood? How much is "And it ain't much!"?
I have used my Pro Planer for years without sharpening the blades. Mostly Oak and hard Maple.
ERLover
Post by ERLover »
What was the feed rate? Depth of cut? Brd Ft ran through it? Condition of the blades when started?
moggymatt
Post by moggymatt »
I was wishing my blades would last forever but.....
Anyway, after about a year and a half of ordinary use on common boards my project called for cabinet fronts of rustic hickory. The 1st three board Plaines out nicely, no bog down, no issues. But after a few passes with the next three, I started getting what at first I though might be marks from the outfeed roller but I think they are scorch marks. When they started to get worse the motel started to bog down too. Could bee the outfeed roller. IDK.
What do you all think?
Paul B
ERLover
Post by ERLover »
Maybe a good waxing of the tables, it can make a big difference, and clean the roller.
ERLover
Post by ERLover »
Knots and grain changes are tuff on jointer/plainer blades also.
moggymatt wrote:I was wishing my blades would last forever but.....
If you are bogging the motor down my guess is too high a feed rate with too deep of a cut along with dull blades.
FWIW, I have never had the motor bog down on my Pro Planer. But, I seldom takes cuts greater than 1/16" and I don't ever run it at the fastest feed rate either.
moggymatt
Post by moggymatt »
I had it on the slowest speed setting and only taking off a 1/4 turn of the handle. I'm pretty sure it's dull blades. Easy enough to sharpen.
Paul B
